So who actually has a car that runs at the moment?
Think its about time we had a cruise or something. But all depends on who has a car to drive
Nah got no cars except the R32 which does not go cruising.
Yeah its not exactaly a stealth cruiser :P
Was just thinking you still have the NUR33 plates...... What are they going on next? Or are they just wall posters now?
Edited by 89CAL
NUR33 Plates are going on the Drift Car ;)
Got some new goodies for it this week will be putting the engine back together over the next couple of days. Just gotta order the new intake and exhaust manifolds.
All this talk about cars annoys me.. I want to buy another but I don't know what to buy.
Any suggestions?
Buy anything lol, GTR's are good but they come with a very expensive Tax epically R34's just ask Kingy, High Quality aftermarket parts are super expensive (Been there done that) and if not done right has great potential to bite you in the arse hard like any RB engine would. My choice of car at the moment would be Evo IX hands down. Cheap to purchase, cheap to buy parts for and handle anything you can throw at it.
My missus has given me the green light for my next project car 67 - 69 Chevy Camaro Coupe with LS9 conversion Old school car with New School running gear with a JDM style to it, will be a few years before that happens lol. Starting to research how that's gonna go i want a nice weekend cruiser with infinite Nm of torque :woot: .
I got one in Victoria street a few years ago. Never got around to paying it and never heard anything about it again. Maybe just lucky
definitely lucky! it says on the ticket that if its not paid the balance will increase. i have til 11th next month so whatever ill just pay it. still annoying as f**k though
I'm up for a drive for sure, can bring a few more guys with Skylines too.
Buy a V35 Jono :) Leon's missus has just got a white one
Havent seen it in the flesh but it looks pretty damn nice from the photo I've seen
Just copped a f*cking $80 parking fine while i was getting a haircut in victoria street. How can they issue fines when there's only 10 parking spots in the whole street, shits f*cked.
Yeah I got one for parking in the middle of the street outside Hogs Breath once when I was away for about 5 mins getting sushi. It is a loading zone, but they hardly ever patrol that area I think. Just unlucky really
On another note. I emailed Titan motorsport about an ATI balancer for an RB25 and they said there is no such thing and werent interested at all in helping
Emailed another American performance parts shop and they are going to contact ATI or get a custom one made.... lol no idea how expensive that is or if its just like one of the others I've seen which is just a mix of a few different ATI balancers
They won't make one for a RB25 you will need to get one for a RB26
Got a Little Bit done today not a great deal but, picked up some more bits today like a Full Z32 Gearbox Conversion Kit all Machined up ready to bolt up and also got a ATS Triple Plate Clutch for good measure to handle plenty of abuse :rolleyes:.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
