Faaaarrrrrrk. Looking good man, i love that you've already got your rims when the car is still a shell haha!
When you build a stance/hellaflush car you buy massive rims first then build the car around them to make sure they fit perfect. There is a method to this madness + the wheels where on special too cheap to pass up lol.
That is a good idea now that i think about it, so you can modify fenders to make sure they fit too i guess.
grill looks good ay... and yeah bens right. u buy rims then build car
Thanks, i'm happy with it
Wow, Bowen.... That's a little different to Sunny coast :P
I went through there once in my car, stayed there the night. Locals were staring at my car as if it was a Ferrari so im led to believe that there arent really any Skylines there.
Lol oh wow, that will be a little bit different then! Yeah very big change, but gotta follow the money :) It will be nice to experience some of the north of the country, Ive been south plenty so Im looking forward to it. I may have to make the odd trip to mackay or townsville tho i feel. It will be nice to be able to go to the footy and not have to watch the broncos!! :D
Hey mate, Bowen has a really nice beach.. that's all i know. Went up there for a cruise with 5 other cars the other week, it's a pretty shit road and the town is nothing special. Should definitely be interesting for you man, it's a big big change from where you're coming from!
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
