all i supplied was a long motor, clutch, g/box and ecu/wiring.... andrew supplied the head and gaskets so i built it after i completely stripped it and checked EVERYTHING... he then took it to adrenalin and they installed it there, changed stuff around, made pipes ect and got it running. it also has 272 pon cams not 280+.... it also got tuned in mackay by steven at RDP and was making 242rwkw on 20 pound.... YES WITH THAT SHIT TUNE.... the one u keep blaming everyone for
And you keep hassling me about my tunes, when you've never driven a car or even been in a car that I have done. You can't even tell the difference between a bad tune and an intercooler pipe blowing off lol.
Anyway, I have proven that you are sheep countless times. And its a fact that this thread went to shit as soon as you started posting.
Edited by The Mafia
f**k me this is bullshit what the f**k is wrong with Mackay people, f**king whining and bitching..... some flamin mongrel get Jerry Springer down here to sort this shit out or I'm starting a new Mackay thread and if anyone bitches on it i'll drive around your house and slap some sense into you, f**k no wonder I live like a hobbit and build my own cars in piece and harmony otherwise some flamin mongrel would get a Snap-on spanner thrown at their face. :domokun: I'm not posting on this thread anymore, I don't want to be associated with crap. I'll stick to my project build threads if any flamin mongrel wants to talk to me i'll be there chilling the f**k out with a ice cold beer.
So... How much is a decent soldering kit? And where might I purchsse one? I've got bulk wire work I need to do on the 33.
Also, does anyone know how to connect a watercooled Wastegate? Like... Does the water return from the turbo just get rerouted into the wastegate?
by ben xoxo.....
and rob, autobarn, supercheap, repco, bunnings... f**k basicly anywhere will sell u a soldering iron. gas or electric.
with the gate u can do it that way... u pretty much want water in and water out
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
