Just received an e-mail from Will at JHH. After a lot of miscommunication and non-communication... My block is assembled... And my head has been ported, guides installed and valve seats cut. All that is left is the clean and final assembly! :):):):):)
bababababannnnggg!
I'm confident! :)
Put the tensioners on tomorrow or monday if I get a chance then the head can go on, put the timing belt on, make sure the pistons dont hit the valves (important step lol) and then I'll be running out of excuses. May take the Skyline off the road next time I'm home from work and pull the other engine out, send the clutch away and have it ready to put the new one in the round after
I REALLY am running out of excuses not to finish it now
More photos, today made some pretty big steps :)
Manifold and turbo arent bolted on at the moment, just there for some final alignment/modifications. So hopefully will pull the car off the road next time I'm back from work, work out the dump/wastegate setup and then get it all happening :)
Looks like an dirty old diesel turbo Cal.
Get off the drugs :P
I'm keen for first startup but will be a bit nervous as well to see if the oil control is gonna be alright.
I've always been a fan of s15's. They feel alot faster with minimal mods compared to skylines at least. 3071 and supporting mods would be fun enough
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
