So I'm selling Both of my new Apexi Power FC's, have got a response from the Apexi engineers and they say its my tune, but I've used the base map and played around with the timing in these areas with no results
So If anyone knows someone after an R33 GTST Apexi Power FC. I have 2 brand new ones. STATUS and others said they have had no troubles with these so it may just be an issue with my car, but I'm not really willing to chase it if they arent going to offer support.
Chasing $1100 for each Power FC. They are both the latest models, come with everything in box including new EL hand controllers.
Looks like I'm getting a link
Nah nothing to crazy, sensible car
just getting an A4, hopefully with an S-line kit and decent mags on it. Probably the only thing I'd touch would be the wheels. Park the Skyline most of the time, drive something that doesnt chew fuel and will be practical later in life. Thinking ahead and all that.
Should be sweet anyway. Bit nicer then a commodore
anyone know who stocks Motul 300v chrono 10w40 engine oil locally? tried calling autobarn but they were busy so i'll duck in there after work just wanting to know if anyone knew for sure a shop that has it in town.
cheers
I prefer Castrol edge engine oil over the Motul Oil. Castrol edge can cop a fair bit of punishment, tried and tested in our GTR and a lot of sport compact drag cars use it as well. Motul oil is very over priced.
I have Castrol edge in mine, honestly there isn't that much difference between them all. I perfer the Motul, it seems a bit nicer (quieter) with it, but at the end of the day most of the higher end mainstream oils will do the job.
I changed from Motul puerly to make life easier for me. I was having to order oil every time, where as going down to supercheap and grabbing a bottle of Castrol is much easier
I'm trying to get some info on Link + Link accessories but not having much luck with it. So far because I'm not that desperate for it I have just been emailing some Australian dealers and have emailed Link ECU direct. Link ECU gave me the closest dealer to me (Townsville) which I already knew but fair enough they are doing there job. At the moment I'm trying to find the info I need, I think I need the expansion cable to run the IAT sensor (as it uses an extra input) so basically I just want to know this and if they supply boost solenoids.
Also, My Power FC's are still for sale :)
Fault is with my car not the unit itself for those playing at home
Edited by 89CAL
That's the plan. Finally heard back from someone about getting one. Just gotta add a 4 bar map sensor and boost solenoid and should be a done deal.
Is there any setup for the knock control? I can see you can minister individual cylinders but I'm hoping it uses the stock sensors without to.much stuffing around. Haven't looked at the pin outs for the knock sensors might do that later
Vct setup looks easy, boost looks a bit harder to setup but probably just a matter of playing around with it. Hopefully won't be to hard to tune. Doesn't look to bad just alot more setup then the power fc
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
