Yeah tomoro night. Ill head back down when i put new comp in and tune new turbo. Speaking of which did u still have the data logger for the d jetro , and the intake that had those fittings in ben. Make it a swap not a drill out and tap
Ah I go to work tomorrow night but I will be attending Slamfest next weekend at Palmyra.
The GTR will not be attending. The engine has currently been removed, the clutch was absolutely rooted, has been sent to NPC for rebuild and slight modification. Engine got all packaged up today and overnight freighted to Godzilla Motorsport for a B'day rebuild / freshen up. The block is getting grout filled solid so will be stronger, block is also getting O'ring treatment, head getting super-tech valvetrain for higher RPM, new Maran 5000cc fuel injectors for the Methanol Fuel, plus other this maybe. All in name of more power and torque will be up around 1400HP :woot: that should increase our top end MPH and get the low 8's.
Yeah I got all the datalogger gear hear Jordan just got to come get it, as for drilling out No.3 &4 intake runners for the map sensor fittings, I got another idea for that, save you pulling the whole plenum off. I will do it how Kingy's old D Jetro setup was and use the 2 points at either end of the air equaliser rail. It worked fine on his car.I'll try catch up with you next week and show you.
I know lol. Depending on what he wants to get out of it, FC-Pro graphs and records data alot better then FC edit will. But FC edit might be all he needs. Offer is there Jordan if you want to do some data logging
I have no clue lol. I just need it for grant so he can tune it once its in. And it will be going to vipec or something in the future just want to get rid of afms. When are u home ben. Im heading out of town tomoro for a week or so. So if next werkend ur free ill come round. And will let u know cal cheers for that.
Ahh ok
Yeah I perfer FC-Edit for tuning. FC-Pro is just great for logging if you have a problem. You can record a run and then play it back and view around 12 parameters at the same time on playback. its a good program
ah righto, to easy cal, ill let grant know and see which one he would want. matt came round and i seen what you was talking bout ben. easy as. just a splice into the boost lines, just need a few t pieces from somewhere and should have it sorted within the month.
Just in case anyone is interested. I have some AH Astra headlights I want to get rid of. Trying to sell them for $20 on facebook but free to anyone on here who wnats them. Bit of a long shot anyway. The lenses are just a bit yellowed, other then that no real issues
Let me know
For those who missed it on Facebook, going to do a little plug for Craved Coatings here. Did a fantastic job of my cam covers, very happy with the colour and finish on them. They look great in real life
Photos:
1048514_10151487800167793_2038528849_o_z
1063742_10151487802862793_1199754537_o_z
They're pretty average quality photos as they are only off my phone but you get the idea :)
Got a better set of injectors sitting in the shed if anyone is planning on running over 500hp on E85. I got 6x 2000cc ID injectors have proven to make over 1000HP old drag car injector, or maybe I keep them for my next project.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
