Hey guys, just thought I'd say hey. I'm that white R34 with a sun roof that's been running around for a few months now. ;)
Hey mate, if you have Facebook, there is a friendly bunch of JDM people that hang out some nights.
https://www.facebook.com/groups/272895909427010/
They organize meets every week. Come down and say hello if you want
Would have been cool, but too much black I think. Maybe the cam covers would have looked good carbon dipped. I originally wanted to do them in some sort of carbon firbre, but kinda glad I didnt now. The EGO Grey metallic looks really good when the sun hits it
anyone see any draw back to putting a couple of the carbon fibre r35 gtr vents on a stock bonnet.. maybe see about a ztune vent in the middle aswell.. just maybe.. ztune only if it can be done legally..
You've got to be careful if you're cutting the bonnet. If you're just sticking them on top, that should be fine. All vents need to be rearward facing though.
You can cut the bonnet but not the bracing under it. I'd just avoid cutting it.
yeah I wanted to keep all bracing, I thought that's where the issues lie, in cutting or modifying the bracing. but if you can cut holes out in between or even a sheet, as in a square the size of the z tune vents and fibre glass it in, keeping all bracing there wasn't much of an issue. hoping. if I can find a carbon fibre z tune vent that is.
  • 3 weeks later...
New Radiator in the Skyline cause the old one cracked. Ready for Test and Tune Friday. For once it lines up while I'm home and the weather is cold
So it will probably rain now.
Will run the dodgy dash cam I have but have seriously been thinking of buying a go-pro for the outside. Just can't decide if I would use it enough for it to be worthwhile
Anyone else heading out to test and tune on friday?
