Hey Sean
Check this out would be a awesome investment:
http://www.skylinesa...22#entry6710922
I was just looking at that thread lol, i am a sucker for dish so i'm not a fan of these.
However, these are my next set of wheels for sure but probably in a 19''
Work Varianza T1S, they are discontinued but there's still a vendor in the states that's got a good supply of them so hopefully when i'm ready for my next set i can get my hands on these.
Edited by Seano350GT
Just get a set like my Work S1R's
JDM Concept have these 20" VS XX
WAS $3880, NOW $3180 PICK UP IN SYDNEY, DELIVERY IS EXTRA [save $700]
[F] 5-114.3 20X9.5 +6 A-disk [90mm dish]
[R] 5-114.3 20X10.5 +O O-disk [122mm dish]
COLOUR: [bKB] Black Burning
Z33 above is using the exact spec
i've never understood what the difference is between a disk and o disk, what is it?
yeah Tony loads of dish, they are meant to clear my brembo's too lol.
Ben i can't see those wheels on my work computer but i'll google them
Googled them, they look sweet i'd definitely want them in a step lip and in 19''. They are similar to miesters and even te37's
So Apparently the ARP bolts at their slightly higher then OEM torque specs caused the girdle to distort slightly and this is why the crank was locking up. didnt appear as a problem at standard torque but did at ARP torque settings.
So hopefully all good now
Today I managed to get the oil pump fitted up, sat the timing gear and plates in, knocked all the welsch plugs in, fitted the knock sensors and fittings to the block, (all will probably have to come back out but saves losing them in the mess i have) and dummy fitted the sump. Still trying to find an alternative to plumbing the rear head drain into the intake side of the sump. It's so busy on that side with the starter motor, alot of the wiring and water plumbing as well as the underside of the manifold. But its the best place to plumb it because of the way the sump baffle slopes. Guess it will have to wait till the engine is more together to see where it will fit
Yeah the turbo drain is an option. But the new turbo doesnt really have any oil restriction as compared to the HKS item I have. so will have alot more oil flowing through it. But realistically there wont be that much oil combined from the head drain and the turbo drain to prevent the turbo drain from doing its job.
think that might be the best option at the moment anyway, May just go with this. Yes I realise the head drain thing is either a good thing or completely useless depending on who you talk to. But as far as I can see, if your accelerating, your pushing oil to the back, so it cant hurt to have a drain there. My logic might not be right, but I feel it necessarty
It's not useless cal, just doesn't drain much.
It's useful because if you can equalise the pressure between the head and the sump, the oil will drain better.
For example, if the pressure in the sump is greater than the head, oil isn't going to want to head that way easily.
and pretty sure just cos theres no restricter in ur turbo feed its still like 1/4 or smaller then the size of ur drain, so i would think the drain will be big enuff for the turbo n head aswell..... does that make sense ?? ive had a few beers :cheers:
Edited by dysonest
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
