hey guys
short storey / question is:
brothers got an r32gtst and its having a chronic steering wheel shaking above 110km/h.
could the tail shaft / tail shaft universal joints becausing this?
long storey is;
he's had it balanced and aligned by 3-4 ppl, had joints / bushes etc changed, spent over $1k in suspension parts with no effect.
and he does regular driving on highways, the wobbling / shaking is bad enough to cause pain and numbness after an hour or so, so its bad.
i pulled out the tail shaft but i'm no mechanic to know if theres anything wrong with it, 2 of the uni joints seemed to like to 'click' into the central position, i'm not sure if this is normal or not
i know you can get 1 piece tailshafts made but its $500 more that does not want ot be spent if it doesnt fix the problem, does anyone have advice / similar situation experiences?
anyone know of a tailshaft / gearbox place that would look at the shaft and give an honest opinion if its dead or could be causing vibrations? thanks for any help :(
https://www.sau.com.au/forums/topic/139896-wobbling-steering-wheel/
and they have been taken off and balanced by 3 places at least
The balancing won't do crap if the tyres are warped.. and may actually still balance ok. I've had that before on another car. Peeved me off no end for 6 months until I tried a different set of rims as a last resort.
My guess is that it wouldn't be the tail shaft through the steering.. rest of the car, sure, but tailshaft goes from engine -> gearbox -> diff.. the rack isn't involved.
Spot on gordo!
I had a dodgy tailshaft after my gearbox conversion. You feel it thru the bottom of the seat and in your back.
I've also had egged tyres on the car, that you feel, and there is nothing you can do about it. A balance wont pick it up as its not a weight difference in the tyre or wheel. My bet is the tyres.
My tail shaft uni joint is shot to hell in my commodore. It shakes the steering wheel to the shit house.
Change the uni joint. Problem gone.
uni joint approx: $15 from Repco.
My dad has also had many uni joints go, with EXACT same problem. If he gets on the gas, and the shaking disappears, it's definetely tail shaft.
i am in the middle of sorting a similar problem out myself i have replaced the rear half of the 2 piece tailshaft but have not balanced it yet with the front half, so im not 100% sure if this is the problem or not. but i am in the process of replacing all suspesion components including steering rack mount, radius bushes, front and rear camber adjustables.... then full wheel alignment, im going to see if this has any affect on the cars driving, if not im going to start with the tailshaft balance then maybe a steering rack overhaul if they think its needed. suck but there is nothing i can do about it but try to eliminate the sources 1 by 1.
imchecking all the little thing slike tyres aswell on the way but going to wait till after wednesday to see when it all gets done.
turns out the joints couldnt be serviced cheaply
got a new one piece tailshaft
brother reports that the problem is worst then before?
he is now going to sell the car :yes:
took me 2-3 years to convince him he needed boost. now this happens :(
Edited by InterCooL
he had the wheels balanced and aligned again
had 3 different people confirm that the suspension is tight as
no one knows whast the go now....
i'll see if i can get a mate to swap all 4 wheels / tyres this w/e and see if that makes any diff...
it's been alinged like 4-5 times recently, it was done today even
i plan on changing all the tyres / rims on it this w/e hopefulllly
i'm assuming the tailshaft was balanced before putting in, they custom made it and the place brags to make them for gtr drag skylines so you'd think they'd make on that can go over 100km/h with no worries :
Is the steeering rack securely fitted? Bolts tight? Bushes not worn?
My old R31 had stuffed steering rack bushes and the bolts kept coming loose. Maybe check that.
Also check your front hubs don't have excessive runout. You can check that with a dial indicator.
Could be a front wheel bearing problem?
Has the car got any evidence of being in an accident?
Edited by DRFT
Flat spots in the tyres FTW.
When I bought my car it had the shakes real bad over 100km/h. Turned out the previous owner had locked it up just before I picked it up. No amount of balancing fixed the problem...had to go 4 new tyres.
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
