Yep, looks right.
Now the RS FOUR S has an R33 GTR gearbox, it uses a 3/4" slave & 5/8" master.
Looks like you have the same slave (3/4"), but cant quite make out the sizing on the master where the bleeder nipple is. I reckon it will be the 5/8" though.
Do they have fluid flow at all 3 bleeders?
Bleeding them from scratch can be a real pain, as there are 3 bleed points.
Bench bleeding the master is the way to go, then I would open the other 2 bleeders & gravity bleed. Once fluid shows at the second nipple, close it, & gravity bleed to the slave. Once fluid shows, then go back & bleed at the second point with 2 half pedal pushes. Do the same for the slave. This process shouldn't take more than 30-40 minutes.
Failing that, i'd suspect an install problem with the release bearing.
Cool thanks man!
I'll ask them to re-bleed thoroughly and see if that helps, and if not check the thrust bearing again.
The thrust bearing is brand new and came with the clutch kit, I assume that shouldn't be the cause but who knows.
EDIT: And you're right, it says 5/8" on the bleeder nipple, found that in my pics.
Edited by V28VX37
Have you read the link I posted?
The refit of the gearbox is critical. Letting the weight of the gearbox via the input shaft rest on the pressure plate can/will damage the circlip that retains the release bearing. This is a pain in the bum, as you have to be REALLY careful & it's near impossible to avoid, even with the engine tilted all the way back!
If this is the issue, it's gearbox out & clutch off, as it's on the inside of the pressure plate. If the circlip is in anyway damaged, bin it, don't try & fix it. I kept my old one & still have it, so PM me & I'll post it to you.....
Ok still more questions, related to warning lights this time. The A/T light blinks when starting the car and then stays on, which was pretty much expected after a conversion. Is there a good way to disable it without pulling the bulb out?
Also, after Wednesday's dyno runs the TCS and Slip lights are now permanently only, too :/ I'll haven't checked the codes yet but has anyone had this after a conversion? I'm still running the auto ECU and the car is running fine..
Ok so I'm getting Code 17 'ABS-TCS control unit circuit' any ideas how to fix this?
Ok I've just checked the older posts in this thread and Ybenasty, R34mac and E_Lu-SHuN (OP) have all reported TCS not working after the conversion so looks like it's a common issue.
Does anyone know how to fix/re-enable TCS when running a manual box with an auto ECU?
  • 4 weeks later...
Hey guys, i am needing a pic of the inhibitor switch bypass. ive done my conversion and just need to do to final wiring to allow car to start and then get reverse lights going. Can someone please PM me the pic of what needs to be done.
  • 1 month later...
Hello Gents, I have my box and about to commence on the conversion .
A question I need to ask on the ER34 GTT auto to manual .
I have the gearbox but no cross member . Do I just need to change the cross member gearbox transmission rubber mount to the manual one to get it to mount on the bolt holes correctly?
don't want to use the two bolt mounting method would like to mount it with 4 bolts as originally intended .
If I change the rubber mount will it line up correctly or is the auto chassis adapted only to the auto cross member ?
Secondly I have the yoke section of the front half of the tail shaft its been cut but we can weld the yoke if need be .
Confirm what is the length of the front half prop shaft on the auto ?
Confirm what is the length of the front half prope shaft on the manual R33 ?
Please help so I know if can cut weld and balance the front half prop shaft to install in my conversion?
thanks in advance .
The shop who did my conversion just reused the original auto crossmember and gearbox mount with the manual box.
We used an R33 coupe tailshaft front part mated to the rear section of my R34 auto sedan, works well.
Hope this helps.
I have some technical questions .
When you say auto rear to manual front prop are you talking about the two halfs meaning a complete front half from a manual onto a complete rear half of auto?
Or are you speaking about joining the Universal joint of the manual prop onto the auto prop section .... meaning the yoke off the manual onto the auto prop joining the two UJs together ?
Did the shop that did your conversion use all four bolt holes of the body section or only two ?
I need to know for sure before I go ahead would like to drive it out the garage the same day I do the conversion and not be stuck .....
Im miles away from any breakers we don't have many of those cars here .
And ordering would take ages online ?
Thanks in advance
Adam
been reading and have found that the auto drive shaft is longer then the manual drive shaft ?
Please advise which is longer and which is shorter ?
Would like to know . if the auto is longer then its easier to weld the Yoke section and UJ on to the shaft .
Hi Adam, sorry I'm not sure of the specifics you're asking about, hopefully someone else here knows.
All I know is that coupe and sedan tail shafts are different, and manual and auto ones are different. However, it's possible to combine them in various ways by the looks of things.
  • Like 1
no no you have some of your info incorrect, the Coupe and Sedan use the same propeller shafts, the only difference comes in the length of the front half of the shaft and the number of splines on the inside of the prop shaft or tail shaft section as its called ( the front half ) so essentially I want to know what have I got to do to make the front half of the tail shaft work with these in hand .
The Yoke and Flex joint section of the front half ( been cut by the breakers in japan using a blow torch )
And the front half of the auto box prop shaft with the smaller Yoke attached ?
Cheers thanks again
  • 1 month later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
