Last night the Hobbies in the Hills, hobby shop above UAS was completly destroyed by fire. The fire did not get down stairs so except for being very wet, UAS survived. My car was getting its clutch replaced and I was lucky enough along with all the cars to get out without a problem. I dont think it is known if UAS will be ok but John has a lot of cleaning up to do!
https://www.sau.com.au/forums/topic/140230-uas-almost-burnt-down/
Theis stock should be Ok but stuff like computers, phones and paper work will be gone.
The bigger issue will be the chance they will have to re-locate because of the dammage to the upper floors might make the building a write off!
Thats a really shitty situation - glad nobody was hurt all the the cars were safe.
Im watching the footage of the fire on TV right now :P Thats one serious blaze
actually apparently one of the fire fighters was injured :P
you would have to expect a hobby shop would go off like an H bomb. all that flamable glue, pressurised spray paint, model rocket engines, heaps of RC car fuel = KABANG with a side dose of KABOOM!
Does anyone know how the blaze started? I really feel for John as he is going to get reamed through no fault of his own.
According to the reports on Sky news, the cause is yet to be determined, but rest assured, that building is completely forked and will no doubt need to be demolished.
from website
URGENT NEWS
Due to fire in adjoining premises you may find it difficult to contact us at the moment.
You can fax us on 9634 8888 or email [email protected]
The phone no 9634 8000 has been diverted to one line so there may be delays until the problem is rectified.
If you have must talk to us, and are unable to do so please call 0425 303 019.
:P:D :D
feel for john and co
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
