Ok so i pulled finger this morning at finally got my RB25DE+T finished.
Its got spark, and its got fuel pressure, but the injectors arent opening...
Vital Info -
Car is using a RB25DE (R33) with:
RB20 Loom
RB20 ECU
RB20 CoilPacks
RB25 NA injectors
RB20 AFM
RB25 CAS
RB25 TPS
What i had to do was cut the injector plugs off the RB25 loom and replace the injector plugs in the RB20 loom with the said RB25 items. This was simple, as all the signal wires are the same colour as the RB20 ones, however the common earth is a different (yet constant) colour..
Ok so problem: when i tested with a test light, the common earth on the injector loom will light up the test light when it is earthed on the battery's negative terminal.
Why arent i getting a signal to the injectors?
Is the CAS (which i know controls the injector pulse) not compatible with the RB20 ECU?
The CAS looks identicle, and the plug goes straight on, but the part numbers are different.
:P ,,,, that is me right now.
https://www.sau.com.au/forums/topic/140332-injector-wiring/
Because it's a common power, not a common earth? So i'm assuming your injectors have no power maybe?
Except your test light says you have power.
You wouldn't have spark if the cas was the wrong one, though there are some differences between early rb25 and rb20 ones i think you have gotten lucky maybe.
Anyone know if the rb25de injectors are high of low impedance? 20 are high. 25 may be low and popped something. easy enough to measure on the car with a multimeter.
Check that the injector ground wire at the ecu is earthed. Can't find my pinout diagram so can't tell you the pin off the top of my head.
check for error codes
check fuses and wiring back to the ecu, jury rig a positive off the battery directly to the common power wire for the injectors to ensure you have power.
https://www.sau.com.au/forums/topic/140332-injector-wiring/#findComment-2614798
yeah your right, if the CAS wasnt working, it would not spark!
So that rules that theory out...
The Injector loom is earthed at the two earth points on the upper radiator hose inlet next to the two temp sensors...
The block is earthed out correctly...
ill buy a node light tommorow and have a looksee... man i hate wiring!
https://www.sau.com.au/forums/topic/140332-injector-wiring/#findComment-2614930
bump
experts needed please
As stated earlier, there is NO common ground for the injectors, thay are fed battery voltage from the EFI relay, the ECU turns the injectors on by grounding them. You should have battery voltage to BOTH sides of the injectors with the key on, engine off. Should be battery voltage all the way to the ECU unless engine is cfranking or running, then it should flash on and off and ecu grounds them./
https://www.sau.com.au/forums/topic/140332-injector-wiring/#findComment-2616476
ok i understand that now.
1st i will check if the injectors are getting pulsed at the main injector plug, then i will chase it back up the loom from there..
is said injector loom fused? maybe i have blown a fuse?
https://www.sau.com.au/forums/topic/140332-injector-wiring/#findComment-2618980
Man you gotta be serious, I'm having the same problem.. just after I ripped apart my plenum and took out my injectors to be cleaned and flow tested..
now i cant start my car.. just put everything back together like 1 hour ago and nothing.. no injector pulse....
https://www.sau.com.au/forums/topic/140332-injector-wiring/#findComment-2618998
you dont have the injector 12v live hooked up. the negative signal will be pulsing fine from the ecu that doesnt stuff up.
You know what the common wire is on the loom, I thinks its light grey for a rb25 loom, you need to hook this up to a 12v relay and it will start as mentioned.
Dont hook it up to a live without a relay.
Edit: just notices you have a 20 loom, so whatever the constant wire is for that prob wont be light grey.
Edited by James_03
https://www.sau.com.au/forums/topic/140332-injector-wiring/#findComment-2619339
ok so i've got power to both sides of the injector plugs...
i just dont have a good pulsed earth...
my ECU thinks its controlling RB20 260cc top feed injectors
but its really controlling RB25 260cc side feed injectors...
do i need a resistor pack?
https://www.sau.com.au/forums/topic/140332-injector-wiring/#findComment-2635833
Grab a multimeter and check the impendence on the rb25 injectors, just put it on ohms and put it on the injector pins.
https://www.sau.com.au/forums/topic/140332-injector-wiring/#findComment-2636538
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
