im just looking around at different RB20 turbo combos and have a question re power ratings manufacturers quote on turbos..
for example the HKS GT2510 unit says its good for 300hp
now is that an approximate figure for an "efficient power" rating or a "maximum flow" power rating?
https://www.sau.com.au/forums/topic/140403-turbo-hp-rating-question/
you got what you got.. say 205 rwkw is the most you can get.. at least that turbo has a good resell value and you can upgrade without any issues.....
that rating is HP at the engine.. a skyline can lose 25% 0 %40 at the rear wheels dependant on configuration.
You would have a really zippy car with that setup... make sure you got the supporting mods before you upgrade :rolleyes:
It has absolutely nothing to do with engine power.
The standard method of sizing turbos used by Garrett and most other other turbo companies these days, only refers to the compressor airflow. If you look at a compressor map, and draw a horizontal line at a pressure ratio of 2.0 (14.7 psi boost).
You then move along that line into the choke region at the right, until the adiabatic efficiency drops to 60%. The airflow figure that the turbo can produce one bar of boost at 60% is the airflow rating for that sized compressor.
You then assume 1.5 CFM per horsepower to turn that airflow into horsepower.
You then know that a 300 Hp turbo can supply 450 CFM of air at 14.7psi boost with an adiabatic efficiency of 60%.
It may produce 300 Hp on a real engine, or it may even produce a lot more than that at much higher boost pressures. Or a lot less power if the turbo is not well matched to the engine.
It is just a very convenient way of comparing one sized compressor to another size of compressor by measuring both under exactly the same operating conditions.
cheers to the other responses, but this was the kind of generalised answer i was after, thanks warpspeed.
sorry if i worded the thread incorrectly peeps :devil:
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
