Guys,
click the link for the photos of the sprinter at the chase.... pretty disturbing!
http://www.antilag.com/forums/showthread.p...2136&page=2
2nd post down....
  • Replies 68
hi all
it was my father that was there taking photos over the weekend and there are more photos available. Everyone who was racing over the two days and some past events will be on his website. We are always putting more on
I was there in the gts4 keeping those gtrs on there toes.
the web page is:
www.moffittphotography.com
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
