*UPDATED WITH FINAL INFORMATION*
TINT-A-CAR CAMBERWELL TINT-YOUR-CAR DAY/MEET
ok, its all booked in for saturday may 3rd @ camberwell Tint-A-Car, 169 Camberwell Road EAST HAWTHORN (about 50m from camberwell junction)
basically what is going to happen is we are all going to meet @ the tint-a-car on the side of the road @ 8:30AM and then we're going to arrange who gets done at what times, we will then after we've left the fist few cars to be done head off to a local park with the bbq's etc and all that to setup (this part about the bqq is optional i wanty your opinion on whether we should do it or not) and then muck around in the park or whatever possibly even cruise (but its a very busy area so i doubt that would work) and the guys at the place will cal us as cars are done adn to bring more cars so we play musical cars a bit then have the bbq at lunch time, we have thew entire place booked for the day so getting all 11 cars done wont be a problem
please let me know what u think of the BBQ idea as if we dont do that we can all have our own separate times and come in on our onw stead and get the car done then leave or whatever
*PRICING*
$180 for full coupe done in formula one plus (35% best quality or 20% best quality)
if you want say just he sides done (ie. no back window) then it will cost 2/3s of the price for full eg. $120
I ALSO NEED TO KNOW OF ANY OF THE BELOW LISTED DEFINITES CANNOT MAKE IT AS I WILL PUT SOMEONE ELSE IN THEIR SPOT
DEFINITES THAT ARE BOOKED IN:
DJ_L3ThAL
Interloper
DAHXX
R31Nismoid
Greg
Al
aybee
predator666
Horus
my g/fs bro with his soarer
(B1) MR_fanny
Backups if definites drop out:
mash
Undecided
funkymonkey
chopobo
king_kw13
Wardest
:burnout: :burnout: :burnout: :burnout: :burnout: :burnout: :burnout: :burnout:
  • Replies 120
ok wel looks like we have enough people for a good enough day, more people would be great, im sure a lot of people still havent seen this thread so ill go ahead and call them and start getting prices etc and we'll all take it from there :)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
