  • Replies 120
oh ok mine's just the standard shelf so its really tight fit!
so is it cool that i'll get there at about 1:30?
the guy that was going to fill in for me for tennis is busy so i have to play. But if its raining, which it is meant to, i'll get there at 8:30 :rolleyes:
is the bbq still going ahead? do you want me to bring meat or anything, or is is byo? what happens about a bbq if its raining?
so howd it go?
Sweet!
Thanks once again DJ for organising this of us all. Compared to the quotes I was getting, this came out at almost a third of what I would've had to pay in Geelong for the exact same tint.
The guys there were great and my bro in law even arranged to come back another day and get his sedan tinted for $195 (normally $495)! I'm impressed with the job but its not as dark as i'd hoped, but i guess its best to stay legal because of insurance.
Thanks to DJ for organising it :P
hows the front of ur car greg....hehe?? got a bandaid on it?j/k
lol that dumb bitch! i was so ****ing pissed at her. she could have just waited for me to back my car out a bit more but no, she just had to run into my car in her crappy wheelchair. she should take some lessons on how to drive the thing.
when my sister (sarah) ran up to her to get her details, sarah said "do you realise you just hit that car?" the disabled bitch is like "errr what did i do" (in a retard voice). what a ****ing idiot.
afterwards i felt bad to have yelled at her because she was disabled, but thats still no excuse for her to hit my car!
apart from that it was a good day :P the scratch polished out so its all good. i doubt she would have had the money to pay me for it anyway
Bugger! I haven't logged into SA for a while and totally missed this!
I have crappy tint on the rear window and the rear quarters, but I heard that if it's factory they can't remove it. Is this true?
I wouldn't mind replacing all of it. I can't see out the rear window at night which is really annoying (and dangerous).
That would not be factory. I don't think R33 came out with a factory tint. The old tint should peel off easily, the guys at the tint-a-car will be able to do it, b4 retinting it for you.
I hope so, thanks! Do you think there will be another tint-your-car day? I'd definately be up for it.
There were a few people who missed out:
Backups if definites drop out:
mash
Undecided
funkymonkey
chopobo
king_kw13
Wardest
Try and organise another one. Ask DJ for the phone number to that tint-a-car place, as he may give you the same deal with less cars.
You can only try.
yer im sure u can work soemthing out, as for me i aint organising another one but i am in the process of organising another meet/day that *may* invovle cheap prices on something we all want/need (but thats for me to know and you to have dreams over) mwahahahahaha
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
