I'm going down to do a few runs :) first time ever, and I will suck! lol
And yeah I'm keen to meet up and go down there as a group.
Oh and with the whole Skyline vs Supra thing. Who cares bout the nitty gritty of the engine/gearbox specs.... Skylines are 10x the sex of any supra :P LOL
:D
Hmmm didn't think you were going to show your face down there...I guess if you don't show now it just proves you really are all TALK and scared!!!
scared of what? catching something from you?
bawahahahahaha
i'll be sure to help talk that gtr up that your "buying"
Keep the personal shit out of it....Stop acting like your 12 years old, im sick to death of reading this shit between you and allara, Hell i dont think i have even met both of you, if you cant keep it civilized , keep your comments to yourselves......both of you!!!
Now...
it only takes max two hours (depending on traffic )to willowbank.
I was thinking along the lines of 1115 am meet at ettamogha then get going no later than 1145am, no later .
I suggest to bring a esky with cold water bottles or the like cause damn it gets hot out there (predicted to be in the 30 degrees tomorrow ) ..also sunscreen and some uhf radios for the drive down, (if you have them).
If we need to stop for others a moby vics well it will be a fly by stop.be fueled and ready to go , otherwise it makes people cranky when others arent on the ball.
Racing starts at 2pm and its going to be great to catch up with some people.
ok this is messed up.
1. i never wrote this. i have been at the beach all day and and have the jelly fish stings on my arm and sides to prove it. not to mention 3 people i was with who can say i was in teh surf life savers area with ice on from around 12:30 until just recently.
2. i dont write like that!
Cool as... I am super stoked about this! Dont know what to wear.....nervous as.
So you racing chris??Need me show you how to drive the thing? hehe.If your racing you will need long pants,jeans are fine and a long sleeve shirt and a helmet , i can bring mine if someone needs one .damn i remember what is was like to race in this heat out there wearing that and damn it aint great but its a ball to get out there!!!
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
