Hi everyone, Just a few questions about oil preassure:
I have a R32 GTR and when im driving along the oil preassure sometimes sits bellow the quater mark when not under heavy load - is this a problem? It generally only happens when im just granny-driving the car about and a good free-rev will generally increase the oil preassure - when giving it a bit more stick (still keeping to within the legal limits of the road of course) the oil preassure usually jumps up a fair bit, between just above the quater mark or just above the half mark, however I have seen it go higher.
if giving it decent stick it will normally stick on the 4 (halfway) mark.
What does this all mean and is it bad?
The car just got back from a major service at GT auto and they didnt say anything about it. Am I just being an old worrysome grandmother?
Thanks
Ian
https://www.sau.com.au/forums/topic/140746-oil-preassure-questions/
theres no such thing as being a worrysome grandmother when it comes to oil pressure.
get it tested by a mechanic who has a manual oil pressure tester asap. it should be at least past the 6bar mark under load.
if it all checks out ok, then replace your oil pressure sender unit.
what oil are you using? thin oil tends to read lower oil pressure.
Im using motul 4100
Is there anything I should be looking out for in particular to indicate that the engine is not getting enough oil? in my last car tappit noises were a sure sign of this.
//edit just reading a another thread about an extra litre of oil... would this be a good idea as a stop-gap until I can get it tested?
Edited by IanB
More info:
On cold-start oil preassure is fine - it doesnt really dip down low until the oil gets hot - even then its only low during idle, sits just bellow the 2 mark on the gauge. Once you get going again it comes back up to anywhere between 1/3rd or 2/3rd's.
Will have it checked on monday however
Driving the car around tonight it was alot better, it sat more or less on the 4 (halfway) mark everywhere I went so I decided to give it some stick, I did notice on WOT it was blowing a fair bit of smoke, but this was only in the higher RPM range (6.5k +) and none at all in just normal driving...
I will take the FMIC pipe off tomorrow and see if theres any oil in there. Should I take it off at the engine side or on the intake side of the intercooler? Additionally, will there be any oil leaking under the car anywhere if it is a turbo seal?
I have put a sheet down under the car tonight to check for drops.
oil seals can be bloody expensive, after buying the car 2 weeks ago I have allready spent alot on it in just maintaince (1.5k so far) so im really hoping its just me being a worrysome grandmother. The car was much better tonight driving it around in all conditions, under heavy and light load and at idle the oil preassures were comperable to my mates R33 GTST.
A bit of smoke is normal for a turbo car on WOT in high RPM is it not?
Or is that just wishful thinking on my behalf?
//edit on closer inspection of the manual there it says at idle there should be 1.5 kg per cm squared, 3 at 2000 RPM and 4.6 at 6000 RPM which, if it translates directly to what the gauge reads (eg 1:1) then thats exactly what my car is doing.
Edited by IanB
How are you seeing the smoke? Revision mirror?
I know at night I can see a cloud of something from mine once it comes on boost.. Especially if theirs headlights behind.
I've sat behind mine with the other half driving, interestingly I can't actually see anything apart from the a little bit of over fuelling.
yeah im thinking it was just overfueling on the ECU's behalf, the engine sounds, boosts and runs smooth as a babies bottom.
Still, as has been said, one can never be too careful. That being said, I just had a major service less then a week ago and GT Auto has a good rep (they mostly deal with high preformance imports, there were 6 - 8 other skylines in their yard when I got there and another one on the dyno being tuned along with some stageias and a XR6T) and I doubt theyd miss something so critical as oil preassure, however I will certainly ask them what they did to make sure that it was a-ok.
And yeah cubes, it was in the rear vission mirror with headlights behind me, looked like a smoky tailwind - prehaps the GTR was just ripping up the dust on the road? :laugh:
Edited by IanB
Overfueling... Just because there's a little haze of black it doesn't mean its running rich.
Mines been tuned to a 12:1 afr and I can see an ever so slight haze.
To see this completely ignore the night time revision check as it really shows it up badly.
Get some one else (the other half) to drive the car with you in pursuit.
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
