Gauging Interest For A Cruise on Monday 21/4/03
  • Replies 76
I'm in for whatever. Hopefully this happens. I'm busting to actually be able to go to one of these.
I don't care when it is, I'm not working Tuesday. The only thing I care about is not scraping my front bar on the driveway. HAHAHAHAHAHAHA.
Note to self: "Gotta change that front"
BBQ would be great..
Bit further out maybe so its like a 1-2 hour cruise though? Most people have the day off so its probably a good one.
Cardinia dam? Its not far from the dandenongs.. reasonable drive and some good picnic areas. But Jells park is good from what I recall.
Dandenongs? Anywhere in Yarra Valley? for somewhere further out.
ns2500: sure you can come :)
wardest: split your bar completely, wire it up and then you don't care anymore :D Ok i lie, I'm gonna spend the time over the holidays fixing it all up and getting a respray.
OK, so set a time, an area,(Jells Park has a lot of BBQ areas) and a list of what people need to bring, IE: meat, utensils, frisbee, etc. and put it all into the first post of the thread. :D
"OOH, lets all go for a cruise, as long as it's near my house, i don't want to drive too far....."
:DWTF :D
Every time we organise something it has to be in the S.E. suburbs. You ALL want to cruise but don't want to drive your cars. :D
This said, i will still be coming (hopefully). :(
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
