except the x force ones flow not much better than what you already have.
Metal cat are the best on the market. get one of them you won't be sorry.
don't go a cheapie
lol, now he tells me :P
from what i understand, the stock cat flows 250ish. the xforce is over twice that. has to be an improvement.
with moderate boost and stock turbo, i reckon it will do the job.
Hmm, i dunno, spending a heap is overkill, its not like there going to be baffled, most hi flow cats will flow pretty good, that said i got a $250 one, which i deemed mid ranged, i'll post dyno results after i get it installed (with new split dump/front mind you), but i'll post em anyway
i ended up taking julion advice and brought a catco cat off BATMBL..
* 3" Catco cat BOLT ON (metal inside, 5" round body **not 4" like Magic cat & Metal cat**, 200csi cell - 706.2 CFM! **Outflows Magic cat & Metal cat**, EPA & CARB approved) - GB price only $360 including delivery
seems priddy good any one know much about this.. ?? is it as good as metal cat??
that's what i reckon. going from a stock compliance cat (hope it's not gutted when i take it out) to a 3" highflow has to see some decent improvements.
Yea if you want to shoot flames theres a straight pipe on ebay for $70.. so theres no point of gettin a highflow 3" and gutting it..
but personaly id rather spend $10k + on mods then give it to the goverment..
But i saw a 32 the other day shooting flames at me.. it was very impressive and i wish it was leagal...
Edited by Fugi
fitted the xforce 3" highflow cat the other day (onto full 3" exhaust). very happy with it.
seems to have gained ~1psi extra boost, so i have to figure it has improved flow somewhat. the exhaust note got a bit deeper, but not really louder, although slightly droney now at certain rpms.
i'm considering a resonator somewhere after the cat, to quieten it down a bit, get rid of the drone. this wouldnt affect flow, would it?
Edited by Munkyb0y
The difference between a 3" ceramic and metallic one might only be 5% peak power. Probably not much with a mildly modded car but would definitely become a potential restriction at big power levels ie >250rwkw.
Personally I got the 3" Catco steel cat & am very pleased.
I got my car dyno'd the same day as another 33 with only a cat back system & had 26KW on him or 177KW at the wheels. No other engine mods besides the full 3" system have been made to my car.
if you want a resonator, get a resonator. its your car. whats right for you might not be right for others.
geee thanks man. :)
itll get rid of the drone and wont harm flow a hell of a lot
that's what i was asking, will it get rid of the drone, affect flow, and is there any recommendations ?
i know very little about resonators, besides they change the area/freq on the way thru, i think.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
