Hey guys .
Some of you guys may know me although i am generally more active on SILWA . I do not get to cruise much as i work nightshift but this is all about to change. For over a year now i have been fabricating Custom Stainless Exhausts and Cooler piping , mainly on the weekends but also during the week. Basically i got soo busy that the stress of working my own business during the day and then working nightshift and working weekends has destroyed my marriage. I have now decided to make my business a full time business.
My business name is KERMIT ENGINEERING ( to be registered shortly) and I am looking for declarations of interest of what i have on offer.
My main Product will be Exhaust systems. I will be offering Custom Stainless Mandrel bent Catback Exhausts for $600 to $650 ( customer to provide muffler ). These exhausts are built to sit as high as possible and are installed with custom Stainless hangers. All welding is TIG . $650 is for a 3" system , a 3.5" system may increase the price a little.
I will also be offering dump pipe back systems also but will quote these on a one by one basis. Obviously a GTR will be more than a GTST because of the twin front pipe layout. Custom dumps are also in the pipeline , first will be custom widemouth dumps and later on will be split dumps .
I also do Cooler piping . So far i have done S13's ( Ca , SR and Rb20 ) and will be offering this when i have the workshop running.
All my work is Custom . I am also happy to modify ' China ' or Xforce products as these never seem to fit properly .
Thank you for your time.
Kermit
So what do you think? :)
https://www.sau.com.au/forums/topic/141182-custom-stainless-exhausts/
  • Replies 353
Posted Images
What about manifolds?
and maybe cat delete pipes? :)
You might have a hard time finding your niche, if your workmanship is up there (which it sounds like it is) you'll get the performance crowds attention and you'll be able to price it accordingly. On the other hand theres probably more ricer types wanting cheap exhausts for there shitboxes.
If you ever need an RB20 test mule I'd be more than happy to help out :rofl:
Best of luck with your new business
do i have a job for you!
i need some custom cooler piping made up to suit my forward facing plenum'ed RB25.
i am also after a twin exhaust for my 33 gts-t..
basically i have a 3.5"system on the car already, and i would like for it to split into a twin 2.25, or twin 2.5" system just behind the dif, and run one to either side of the rear bar, and exit with a 3" chrome tip on either side.
and preferably have the muffler(s) hidden from view.
it doesn't seem like that hard a job to do, just most exhaust places will only offer me the typical 3/3.5" with a cannon system, whereas i want something different.
let me know if you are up to it. :whistling:
sounds good mate. custom twin is no problem but i would have to check the clearance on the drivers side of the fuel tank to exit out of either side of the rear bar. As soon as i have premises sorted i will let you know but this sounds awesome. at the moment as i am still at home i can only do basic catbacks but i am trying to find a place with a workshop . once i have a place with its own workshop i can do this for you no problem. i am also in talks with a motorsports business about renting out part of their workshop. if i can work from home it takes the pressure off until its sorted out.
am definately up for it
kermit
let me know if you are up to it. :D
gimme a look sometime Topaz. sounds simple enough. my GTR is for sale , i always wanted to do the same on that car but spent all my time modding the wifes sil instead.......then she wrote it off
kermit
intake plenums are a possibility. if this business is successful then i wil purchase an ac/dc Tig so that i can make these as well, although its not quite that simple . im a fabricator not an engineer.
Intake piping for a GTR with a D-Jetro?.
I need to those AFM's out of there....
kermit
Maybe take a look in your GTR and see if its doable. I will need to get some silicon connectors and clamps and some APEXi pods as well, so I guess the sizing will be guessed unless you have gap sizes with the pods available, yes?
Do you have a bricks and mortar yet or are you still to move into a shop?
Wil you do things like clamps and silicon connectors?
cheers
Tom
kermit
i've been under the car all weekend trying to remove my driveshaft, and there seems to be a fair bit of clearance for a 2.5" pipe once you get past the rear subframe. (thats where i want it split anyway)
the only issue i see is the tow hook..
Ok, Here a few pics of The 2.5" Stainless Cat Back Exhuast Sytem Made for a Silvia WA Member - DKC for his S13 Sr20de.
Was made From 2.5" Stainless and 1 x 90" Stainless bend (Not polished), Also DKC Supplied a Muffler to Suit it.
Will Try next time to get some better picture for you, But all pictures should work.
Some Pictures Of the "Drift" Angle you can get, also the quality of work, and I also just like the last pic :D
*Note the close up picture of the Weld, Was cleaned up afterwoods, this was pretty much straight after it was done.
Cheers
Edited by GTRboy
exhaust includes fitting of a cat ( stock or highflow , supplied by car owner) and same with the resonator. All of the jobs i have done so far have only required a single muffler . The sound from my GTR is blood curdling and i have so far had no problem from the police. although there was that one time where they couldnt keep up............
kermit
rough idea to fabricate piping for r34 intercooler?
does the exhaust includew cat and resinator? or just pipe
cooler piping for a r34 ? rough quote of 700 inc silicon and clamps.
i have yet to do a skyline and would provide a more accurate quote once i have the car in pieces as i can work out what bends i need etc.
will provide pics shortly of cooler piping that i have done
kermit
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
