easy peasy . as you are suppling the cat . does it come with flanges or do you need them welded on? will remove old one and refit new one with flanges and fit to car for $100 or $120 if i have to modify cat to fit
kermit
I'll need someone to fit my cat when it arrives...if it ever arrives :)
  • Replies 353
Posted Images
Cool Kermit :)
I was told the car doesn't have a cat, whether its there but empty or gone altogether.. and please don't ask me to check cause I wont know what I'm looking at hahaha :) Oh and its coming without flanges, that much I do know :(
I'll Pm you when it arrives :wave:
tis a full day job but if everything is supplied then i will happily do it for $200
kermit
0422549050 can do when ever , during the week is prefered
gtst, sorry i just meant fitting though :) i have the kit already :( just dont trust myself to chop up my front bar.
kermit
awesome, wikkid price, will DEFINITELY be booking this as soon as i know the rest of my schedule. probably be next week though
- Hey everyone.
I just got my car back from Kermit today.
He fitted/modded an exhaust I purchased from ebay to fit my R32 GTR - with a 3 inch hi-flo cat I purchased locally. He custom fitted some flanges to fit the job etc.
I must say, the job was well done, although it took a bit of extra work (by fault of the car) - the fit/finish was a top job all done in a respected time.
Kermit : it sounds 10 times better now, I can actually hear the turbo spool up now - and no - unwanted backfire :O It pulls better etc than before!
I thoroughly recommend the work of Kermit 100% - feel free to PM me for more information.
oh yeah - and Kermit's GTR - is tidy as! - and goes hard :O
All you would have to do is put it back in , they would just give you a yellow sticker and you would put it back before you go over. i wouldnt reccommend it but then again i wouldnt recommend smoking either....
kermit
kermit u wouldnt recomend a cat replacement for astreetu used car correct ? just found out the fines involved if caught? just wanted to make my car sound meaner realy quiet atm
oh u can put it back in easy ? i thought it was a welded piece, well once i get my turbo and new engine mods in i wont be driving it much at all most likeyl weekends only, il be getting another car within the next month or so, i might consider it if its eay to take off and on
would cops often check under the car for a cat ? or mainly the carbon build up on the rear ?
i dont have a cat and i get no carbon build up on my rear bumper and the cars white! but i also do wash my car often soo maby thats why.. soo if you take care of your car you'll be right..
as for cops getting under your car well i HIGHLY doubt it.. its only the pits guys that will spot it
i have a carbon build up but im too lazy to polish it off ( im too hard core ). cops have never looked under my car even when i get pulled for being noisy. takes couple of hours to make , depends on rusty nuts and bolts etc and if cat sensor is seized as i refuse to cut it off ( cut it out instead then it is at least still there just not used).
kermit
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
