Hey Kermit,
I've got a system that is mounted way to low and because of that my middle muffler is a bit mushed, reckon there's much you could do about bring it up a bit higher, or would it just be better to get a full new system?
hey mate , some systems can be modified to sit higher although if you middle muffler is damaged it is possible that a new system would be a good idea . bets bet is to drop in sometime and let me take a look and i can advise you whats best . I am always honest and if the cheaper option is viable then thats what i will recommend.
kermit 0422549050 give us a call
  • Replies 353
Posted Images
  • 1 month later...
hey man
i am wanting to get custom 3inch from cat back wanting to get this done on the 8th feb and as early as possible in the day
thanks
Gordon
pm couldnt be sent because your inbox is full
Hi Kermit,
Your inbox is full... :D
About to buy a dump/front pipe and wondering if I pop into JSHOP some time, what would I be looking at to have this fitted.
Also, while I'm there it would be awesome for you to give me your oppinions on what could be done about my center muffler which is mounted far too low and scrapes on everything. :blink:
hey man
thanks
Gordon
hey mate , i cannot see any problems at all mate . just give us a shout the week before and i will book you in .
kermit 0422549050
hey man
thanks
Gordon
kermit 0422549050
Hi Kermit,
Your inbox is full... :)
Also, while I'm there it would be awesome for you to give me your oppinions on what could be done about my center muffler which is mounted far too low and scrapes on everything. :cheers:
hey mate , its best to give us a call or drop in to discuss prices and then we can discuss how best to repair your muffler problems . just drop in sometime ( text me first to make sure that im on site ) .
kermit 0422549050
hey kermit,
i don't know if you got my PM or not but i wanted to get a quote on a few custom things that i wanted to get done to my exhaust and intake. PM me with a time that is suitable for you.
thanks
hey mate sorry bout my inbox . pm has been replied to
kermit 0422549050
  • 2 months later...
  • 7 months later...
18 months later and I've finally ad my zorst made and fitted by Kermit!
:D:banana: :banana: :banana: :banana: :banana:
It is a beast! I love the note.... I'm super happy! :yes: There is plenty of ground clearance and the workmanship is very neat and tidy.. :yes:
Thanks Kermit! Great work! I thought I'd give this thread a bit of a super-bump! :cheers::D
Edited by Marco-R34GTT
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
