hi there
i've had an issue recently with misfiring.
seems that once the car gets some heat in #2 doesnt want to spark.
Its a RB24 / hks 2530 / pfc / gtr inj etc...
I just tried replacing that one coilpack with about 4 others i had laying around, but no luck. I taped around the bottom of the original one incase there was a hairline crack or something and spark was getting out.
still nothing.
I then took the coilpack out and checked for spark with the base near my intercooler piping. And nothing again...
does this mean that:
- the coilpack is dead
- or possibly that i have an electrical problem and the coilpack isnt getting, power or earth (how would i go about checking this)
Big thanks, need to sort this out asap all help is appreciated
BTW - i have checked the gaps on the plugs all 0.7 and plugs seem to be in good condition
thanks
-Matt
https://www.sau.com.au/forums/topic/141348-no-spark/
Series 1 or 2? Series 1 has the ignitor module mounted on top of the coil cover series 2 has ignitor built into the plug. Try putting the other coil packs on #2 cylinder output. If they then work it's not your coils.
Pretty unusual to have 5 coils fail.
https://www.sau.com.au/forums/topic/141348-no-spark/#findComment-2634040
Best way to check this is Get a timing light and get a Nissan Electrical Manual.Find which wire is which before and after the Ignitor. and check from there,You find that if its not firing on the light before the ignitor you have a problem from the ecu to there.If it firing before the ignitor and not after its the problem.
if its got no Ignitor,You might find a wire is cut or broken and test the same way.If you cannot get a spark still,its the ECU
https://www.sau.com.au/forums/topic/141348-no-spark/#findComment-2634064
i will try isolate the issue some more and then i will try to see if the coilpack which is not working - works on another cylinder. I will also try the igniter pack :ninja:
this is all on a Cefiro RB24 with power FC
thanks for the help - keep the info coming the more i can test the better!
thanks again
-Matt
https://www.sau.com.au/forums/topic/141348-no-spark/#findComment-2634799
could be the wiring harness also.
and a very very slim possibility is that the ecu is dead. my mate had a problem where he could not get number 6 to spark. tried new coils, wiring harness, plugs, everything. it turned out his ecu had melted a hole in the chip when he'd tried wiring up some msd coils.
https://www.sau.com.au/forums/topic/141348-no-spark/#findComment-2637334
well igniter pack made no difference, still the same
swapped plugs around, still the same
swapped coilpacks from 1-2 and 2-1, still the same (#2 being the problem)
earth is good (unless at the back of the plug for coilpack) the middle wire had power (tested with test light). And i wasnt sure what the other wire was for (power / earth etc). this was while the car was running.
pulled the loom for coilpacks out and stripped wiring to check for broken wires. couldnt see any so i just sanded the earth and re-fitted - started perfect and ran smooth.
.... few days later - took to the dyno today... and off the dyno and misfire again :S
any more ideas?
thanks
-Matt
https://www.sau.com.au/forums/topic/141348-no-spark/#findComment-2658790
you don't have any of thet "special" green goo that seems to form in all the nissan connectors do you? Take off the ignighter plug and have a good look inside theplug. is the copper all green? If it is you can clean it with CRC and a toothbrush.
This goo is an excellent insulator and has given me greif on my AFM plug before took me about 2 hours to find why the car would randomly stall for no reason.
https://www.sau.com.au/forums/topic/141348-no-spark/#findComment-2658872
ok CRC being?
it was also brought to my attention that it may have something to do with injector plug connections? and they suggested green shit on plugs... but then all i would think it is not pumping fuel in, but should still be sparking?
looks like loom out again completely - re-solder resistor pack to new location, clean all terminals as best possible and re-try...
ahhhhhh :S
oh and once fitted gizzmo ibc - car now runs way too lean so need re-tune again :S :laugh: fun day for me!
https://www.sau.com.au/forums/topic/141348-no-spark/#findComment-2658893
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
