I’m about to start putting back my engine (RB26) and was wondering what bearings I should be using.
The other parts in the bottom end rebuild are as follows
TOMEI 86.5mm pistons
Standard rods shot peened resized and polished
TOMEI reinforced rod bolts
Standard crank with extended collar
N1 oil and water pumps
Trust sump extension
ARP main and head stud kits
NISMO 1.2mm head gasket
Final power output I’m chasing will be 300awkw if that matters
Any experienced feedback would be appreciated
https://www.sau.com.au/forums/topic/141655-main-and-big-end-bearings/
im goin acl race series....
hey buddy,
i just put some new bearings in my rb26 today.
im running 416awkw but had to do crank collar and sump baffle etc.
ACL black metal race series bearings.
they dont look as nice as normal bearings because they dont get the final stage of treatment where they flash coat them. this improves the bearing to housing contact giving greater heat dissapation, also to prevent any flash plate migration or movement, and improve surface characteristics...
cheers
Jeremy
hey buddy,
cheers
Jeremy
So the ACL black metal race bearings are the goods then? I thought that the ACL race bearings were tri metal bearings which I was told were not good for performance application?
i had acl race series in a vl turbo i had... seemed good and heard lots of good things... few mags i reaD the peoples specs there were acl bearings in alot of cases so they sounded like the go 2 me.
If you want to do things right get nismo bearings you buy them to suit the crank and block so it will remain factory iv got them in my motor and would not ues anything else if there good for a gt500 car then there good for me...
all bearings have sizings, ACL is the same as nismo, well pretty much the same, might find a few microns in difference in sizing..
i ran ACL mains, and nismo big ends on my car tho, had no hassles, will probably do the same when i need to..
Once the rods have been resized the grading numbers become fairly irrelevant though don’t they? My understanding was that you get a standard size bearing and then have the crank ground to get the desired oil clearances. I have no problem forking out for the nismo stuff but the differences in bearing grades on them are measured to the thousands of a mil and I don’t think there is mush that can measure you’re crank and rods that accurately is there?
I've just rebuilt mine using KING bearings seem good so far..
some gear on my build
NISSAN N1 CRANK SHAFT
NISSAN N1 OIL PUMP
NISSAN N1 WATERPUMP
NISSAN GASKET KIT
NISSAN TIMING BELT
EXEDY TWIN PLATE CLUTCH
TOMIE OIL RESTRICTOR
ARIAS FORGED PISTONS
EAGLE RODS
ARP HEAD STUD KIT
COMETIC HEAD GASKET
RESLEAVED BLOCK AND DECK
KING MAIN BEARINGS
KIN BIGEND BEARINGS
PERFORMANCE VALVE SPRINGS
HEAD SERVICED PORT & POLISH AND K LINNERS
SUMP BAFFLES
INJECTOR FLOW TESTING
DRIVE BELTS
NISSAN COOLANT
OIL & FILTERS
HKS 2530 TWIN TURBOS
HKS DUMP PIPES
HKS SUPERDRAGGER 3.5INCH
HKS CAMS
OIL COOLER
HIGHFLOW CAT
850CC DENSO INJECTORS
BOSCH FUEL PUMP
TRUST TWIN PODS
ROM ECU
STRUTE BRACE
REAR SWAY BAR
ENGINE DAMPNER
AFTERMARKET SUSPENSION
17INCH PANASPORT RIMS
BF SCORCHER SLICKS
D JETRO COMING..
EBOOST 2 COMING..
Edited by monga
NISSAN N1 OIL PUMP
NISSAN N1 WATERPUMP
NISSAN GASKET KIT
NISSAN TIMING BELT
EAGLE RODS
ARP HEAD STUD KIT
COMETIC HEAD GASKET
KING MAIN BEARINGS
KIN BIGEND BEARINGS
SUMP BAFFLES
DRIVE BELTS
NISSAN COOLANT
OIL & FILTERS
HKS DUMP PIPES
HKS CAMS
OIL COOLER
HIGHFLOW CAT
BOSCH FUEL PUMP
TRUST TWIN PODS
ROM ECU
STRUTE BRACE
REAR SWAY BAR
ENGINE DAMPNER
BF SCORCHER SLICKS
D JETRO COMING..
EBOOST 2 COMING..
Sounds like one hell of a list. So you got you’re crank ground to suit the bearings?
Well i used ACL and no problemo so far, they seem to handle the abuse, but a bearing will function only if you treat it good ie systematic oil changes, dont overheat you engine etc. but the ACL's are good.
    • I used to have Walbro 255's when they were a pretty common update. (or were they 044? 040?) In any case I had a dirty tank. I thought the tank was good, but I would find the filter would clog in maybe ~50km of driving. If the issue persists, well, your fuel system or tank has crap in it that the pump is sucking up.
    • Hi. Ok thanks for the info. I/we do not know what tune is on that Nistune ECU so it is why there is stock ECU and that Nistune is for later when the car is done. I have guy who tunes Nistune and other ECU so i will then take it to him to see and properly tune for the car   And for the update. On 99,9% it is bad fuel pump. Which is wierd cuz it is like 2 years old(brand new walbro 255) and that filter (also brand new) was dirty.  I was alwaya pumped premium(100) on very good petrol station so i dont know how is that possible...
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
