Hi all,
I thought I might just brag a little about my efforts at the track tonight. I rocked up pretty late to the 7-11 session as i woke up at about 8:15 from an afternoon nap. Thankfully I had the car prepaird and ready to go. So I drove down to willowbank, got through the front gates, changed my plugs, and lined up for my first pass...
I put a little bit of timing in through my hand controller as my current tune is very safe and I have a bit of headroom to play with... Anyway I dropped the tyre pressure in my M/T ET street radials (255 50 16) to 16psi and i was ready to go...
Did a bit of a soft burnout as i didnt want to break anything with the sticky tyres and staged up...
I took onboard about 5500rpm and let the clutch out softly and got a bit of wheelspin of the mark and went down the track full steam ahead...My mates where waiting at the time box with thumbs up so i knew it was a good pass - [email protected] with a 1.8 60 foot...
I was pretty happy but i knew the car had more in it...
On inspection my boost dropped off a bit due to the timing advance so i played with my AVCR to get boost back upto 19psi...
I went back and this time put a little bit more extra timing in as well as a pinch of extra fuel and did a bit of a bigger burnout...I staged up and dialed up about 6500-7000rpm on board and let the clutch go fairly nicely, and the car just planted its arse end down and took of like a m0therfarker! As I was crossing the line i noticed that my shiftlight went off as well...i thought i may have gone up a tad in mph...
When i went back to the timebox my mates where cheering and told me that i reeled of an [email protected]!!!
Whats more impressive I thought was the 1.6 60foot and not breaking anything!!!
Well thats my story for tonight, there is PLENTY more left in the current setup, all I have to do now is play with my cam gears add a bit more boost and hopefully I'll crack an easy 10 at around the 135mph mark on 21ish psi and pump fuel!
A big thanks goes out to Ben and Rob at East Coast Customs for helping me out today with my suspension setup, without their help there is no way I could have done the 1.6 60 footer at the track! Thanks fellas!
Timeslip:
https://www.sau.com.au/forums/topic/141695-went-to-track-last-night-1111312mph/
Thats a solid effort, well done. can you tell us a little about the car? We are from Wollongong so havent seen it before.
Hi all,
Timeslip:
Fark where do i start with the setup...
1992 S13 Silvia:
SR20DET:
20 thou oversized CP pistons
eagle rods
stock crank
arp head studs
tomei headgasket
Ferrea 1mm oversized exhaust valves
HKS valve springs
HKS step 3 cams
HKS Lash killer kit
bit of head porting
Tomei cam gears
custom stainless exhaust manifold
turbonetics 42mm external gate
3" exhaust system
600x300x100 drag cooler
Apexi RX6 turbo - modified...
Splitfire Ignition system
Microtech Ignitor
900cc injectors
twin walbro 550hp intank pumps
Z32 afm
Apexi power fc
Apexi AVCR
Stock S14 5spd box
"Direct clutch" clutch
Thats pretty much it hey...I probably have missed out on a few things here and there but thats the general gist of it...
Timeslip:
http://image-cache.nissansilvia.com/forums...-1162481496.jpg
Whats under the bonnet:
http://image-cache.nissansilvia.com/forums...-1162482183.jpg
Edited by TurbostyleR
Well done dude, saw the pass! What MPH did you clock half track?? - managed 103mph in mine but had bent the tailshaft so had to back off at 3/4 track. Interested to see how it compared to your timeslip considering your time!
Edited by slapper
aaah sweet, you didnt happen to capture it on tape did ya?? lol
Im spewing I didnt take out a vid camera!
What car where you in?
I was doing 100-101mph half track which is suprising, i thought I would have done more as the top end gain seems pretty big considering my shitty power curve...
I should be going back to the track on the 25th if all goes according to plan with 30-60rwhp hike in power midrange and hopefully 80-100rwhp of top end power in my power curve with a bit more boost and a play with my cam timing.
I dont know if i should spend the bucks and get adjustable rear camber arms in order to drop my 60 footer into the 1.5s...
Top work dude, you've had this car ages now, and it keeps getting faster :sleep:
Would help fetching that elusive 10 in conjunction with your power gains, and in the grand scheme of things is $220 bucks really that much?
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
