+++white Face Dials @ Bezels+++ Get In Now
  • Replies 271
Posted Images
UPDATE:
ORDER HAS BEEN PLACED, MONEY SENT OVER, MIKE SHOULD HAVE THEM IN JAPAN, WITH IN A FEW DAYS, THEN A WEEK TO GET TO ME... THEN A DAY OR SO TO GET TO FINAL HOME :(
GIVE OR TAKE A FEW DAYS....
BUT YEAH ALL GOING WELL....
MAYBE ONE DAY ILL HOLD ANOTHER GB. PENDING ON HOW MANY PEOPLE WANT THEM.
CHEERS GUYS.
KEZZA
new update... the order has been filled, and will be sent off to me sometime this week!!!!! NOT LONG NOW.. then once i have them, ill send them out to you all asap!
cheers,
kezza
Kez, I trust that when they are sent out, that they'll be packaged very well in rigid packing?
e.g. I'd prefer not have the guy at the post box try and fold it in half and stuff it into my post box, or have the postman chuck stuff on top of it and put creases and dents in it.
Cheers matey
dude...... no one had any problems with the last GB with packing!
but yeah thanks for the input........................
Not accusing in anyway. I'm sure that you have put a lot of effort into doing things right. I'm just seeking reassurance.
Cheers
Kezza it's been a week since your last reply.
Please post an reply, even if you don't have any new updates. A week's silence makes people nervous! :P
sorry people.. dont get nervous... the stork order has been filled... and im just waiting for them to get to me from jap postal!
along with other stuff i have on order!!!
so dont worry, i have been hounding my mate, just as much! lol
hahahha i know i know!!!!!
they are in brisbane, they have been stuck in customs for the passed week!!! the pricks are trying to charge me 10%GST + 10% import tax... cause they are all worth so much!!!!
But lucky, fingers crossed i have found the loop hole and wont be screwed over by the customs boys!!!
But apart from that they would have been here over a week ago!!! :)
:santa:kezza will be sending off his parcels soon enough :)
im bored!!!!!! I miss my car sooo much!!!! ill share some pics of what she is up to one her paint job!!! shhhhh dont tell anyone!
i have it all in my head of what it will look like in the end APART from the big T wing i have fitted to it!!!
im still unsure on it!!! i spose it wont stick out too much when its alll the same colour as they are, and wont stick out like a booggaannnn! (i hope)
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
