  • Replies 45
I will take any or all of these if you can ship to Sydney, let me know how much you'd like:
Right headlight
Washer bottle (water washer you mentioned above?)
Radiator overflow bottle
Thanks!
HI Guys, i just have Wreck a skyline R33 GTST 96 model all parts are for sale :
-complete motor $2400
-Set of coil over like new $800
-Set of rim with no rubber $300
-RH front door shell only $100
-RH front glass $50
-RH front guard $80
-Front huh $150
-Rear complete brake $350
-Two front seat and rear seat $200
-Feul tank and pump $200
-Center consor $30
-Center surround that go around the dash $80
-Brake master & boost cyclinder $150
-Water washer $20
-That all i can think of at the moment but will update some more list on the weekend and also some picture as well so you can see the parts .You can alway pm me for the parts that you need just incase i do have it and i didnt listed.
do u have a gear box
and where u located
JimX: as i am in sydney just want to let you know the RH head light is S1 if you still want the head light for the lots will be $130
or $30 with out the head light.
Yes I need a series 1 headlight so that is perfect :whistling: I can come around and pick up everything tomorrow afternoon/night if that's ok?
hey, have you got the regulator for the RH doors? If so. i'll take the whole door. I can go pick up immediately whenever your free. Please PM phone number if you have.
Thanks.
r32-25t- no front enforcement bar
The Mafia- the grill i got is like a gtr grill .
BLACK WARRIOR- it a GAB coil over like new that all i know.
STRYKR 33- i only got the switch left and the door shell no motor
most people that pm me i have return your pm.
Edited by playergtr
What car was it originally fitted to? A Series 2?
Can I please have pics? - paceys[at]gmail.com
Edited by The Mafia
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
