Hey Guys, thought to share this with you... i just installed an R34 GTT SMIC onto my R33 GTST and boosted to 10psi + ECU Reset
Current Mods: 3" Split dump + 5" S/Steel CAT + 3" CAT back exhaust + Turbotech
Results: Car comes onto boost MUCH smoother & revs to redline MUCH easier.. there has been a HUGE increase in pull through out the rev range especially in 1st and 2nd gear... Dyno would be nice, any one offering a free dyno pass? lol
Recommendation: Definitely worth the upgrade if you have stock turbo... Proior to this upgrade, the car felt held back and restricted, now the car feels much freer and has noticably unleashed more power... Throws you right back in the seat :wave:
Note: Prior to the SMIC installation, i flushed it with degreaser/hot soapy water and i couldn't believe the amount of black crap that came out! had to reflush about 4 times before it was 100% clean... then ran warm water though to get rid of the soap/chemical residue... i then stuck an old hair dryer in one end and let it sit there for 30min untill it was drip dry.. worked a treat!
Look at the size difference between R33 SMIC Vs R34 SMIC!
Here is a couple short videos while driving home tonight, its just to show the smoothness of boost and ease of rev... (excuse the bad footage due to holding my phone while recording and driving) Hope you like!
video_0004.mpg
video_0003.mpg
Regards,
Sarkis
Edited by QRI05E
  • Replies 68
Posted Images
OH good work! I've already put the 34GTT cooler in, and the turbotech controller... Got all the exhaust parts, but haven't fitted them.
When that's done, i'll shove it up to 10psi... same as you have. Hopefully it'll feel the same!
Can't play vids though =-/
Edited by RANDY
I wonder if a change from a R34 SMIC on a GTT to a FMIC will show the same benefits
No, you will not mate the R33 and R34 turbos are much the same except for a slightly larger exhaust housing on the R34. So unless you upgrading your turbo keep the stock GTT cooler. Its a good unit and you wont loose any throttle response to that of a large frontmount.
always good to see these cheep mods work.
cheers
I was thinking of doing this upgrade but thought if i do end up wanting bigger power i wouldnt want to do another upgrade to fmic. so im just going to get a big fmic, but good luck with your mods!!
Hey Guys, the video's were recorded in mp4 format and wouldn't upload onto SAU i had to change the file extension to .mpg for it to work... if you guys try and open it into real player they will work.. or download any divx codec pack and will work in windows media player...
Just a reply to Nismo God, i am planning for big power in the future, however until i am financially ready for a larger turbo + rebuild + injectors + fuel pump .etc. the R34 SMIC upgrade will give you the full potential out of the stock turbo and setup... these SMIC's have been known to hold anything up to 14psi and 200 - 230rw/kw which is more then the stock turbo, injectors and fuel pump will ever handle... so in my opinion, full exhaust + boost control + R34 SMIC + PFC will give you the maximum and most reliable tuned power out of a stockish R33... and wont break the bank.. Not to mention will not give you any issues with the boys in blue as a FMIC would :whistling:
Cheers,
Sarkis
Edited by QRI05E
yeah i got it to work.
sounds smooth. hard to tell from that vid though.
your exhaust sounds good. 3" turbo back right? any mufflers in the middle? like a resonator after the cat?
Did not realise there was such a difference in model SMIC's!
You could probably put a thermo fan on the front as well to get a bit more from it as the airflow in there could be a bit restricted. Maybe a water sprayer as well just to complete the efficiency of it all. :happy:
Yep i got a full 3"... Split dump ----> 5" s/steel CAT ----> 3" cat back ------> resonator half way ------> 6" Cannon
I love the sound... its just perfect, not too loud and just enough growl to turn heads and let alarms off heheh it was built for performance not noise... 21rw/kw gain on stock boost nothing else was touched....
I used the R34 SMIC Shroud as induction... had to slightly modify it to fit behind the S2 R33 front bar... After a hard thrash (30 min driving) the turbo side of the SMIC was hot and the manifold side was warm/cool... the stock R33 SMIC was all hot after a thrash... made quite a difference...
You can actually hear the car rev out real easily in the video and see how it pulls in mid range... I can feel the difference when driving...
Regards,
Sarkis
Edited by QRI05E
Hahaha Cubes, i eased it to 4000RPM then gave it a hit... same as the other video... She goes real well compared to many other R33's and R34's that i have raced, some with more mods then mine (EBC, PFC, FMIC) :verymad: hehe
Cheers
Edited by QRI05E
Not quite free but hey.
http://www.skylinesaustralia.com/forums/in...howtopic=140448
Entry fee is $50.00 for three power runs with a printout
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
