Hi guys,
Just got my first skyline 2 weeks ago been haveing a blast in it. So far I have put in a new sterio and an immobiliser, I am now looking at getting a auto turbo timer.
What I would like to know is whats the difference between the expensive Apexi, Blitz etc... and the other auto turbo timers they sell over here at autobarn, supercheap auto, repco etc...
Ideally I would like the timer to go under the car sterio because there is a huge gap there from where the old jap sterio use to be.
So any ideas guys on where to get a reasonably good one that dosent cost me too much to purchace and get fitted.
Thanks.
i bought my greddy turbo timer from bt-revolutions - then got it installed at RE Customs.
Any of the sponsers of SAU will be worth while checking. I got the greddy one cos its a turbo timer, and also calculates the 0-100 time and 0-400m etc....but the other good one is the Apexi timer, but thats only a timer.
Edit - the HKS one is a bit more expensive, but the autobarn guys keep saying that its caused their customers a lot of problems. I dont know how true that is - but i dont trust autobarn cos the dickhead (must be like 20 years old and working as a casual) gave me the wrong wheel lock nuts and said that he is sure it will fit my wheels.... So my advise is to go to someone who knows their stuff, a proper import mechanic or stores that deal with imports and accessories for imports.....
Edited by emsta2003
my greddy FAT broke within like 12months or something.. meanwhile the HKS Type 1 (on diff car) has been going for nearly 5 yrs now.. Haven't tried the Blitz but personally I think its ugly.
My other half said bring over some beer and he'll install it for it you.. but we're in Lalor/Epping.. so depends how far away you are.
Best bet is to get a HKS with a harness.. Jaycar have cheap turbo timers as well but you have to assemble them, I think there's a group buy going atm through funkymonkey/Shan.. don't get a TT from Autobarn caus they're ridiculously priced (high overheads what can you do).
How about you DON'T buy one and save both the money of the timer and install?
You need a turbo timer as much as a glorified Lancer needs a vortex generator.
Biggest wastes of money ever - just drive the car easily for 2-3 minutes before you stop - or if you are at the track, let it run for a while in the pits and cool down.
Now buy me a case of Carlton Draught and you'll still be $60 ahead.
Throw Andrew from Kudos Motorsport (sponsor on here) a PM about his Pivot Super Baby Timers, good price and nice and simple to fit and use, although IMO a very popular choice is the apexi T/T because of its extra functions and price Usually around the $120 mark.
Im personally about to buy a Pivot TT and install myself, if u can install a deck, a TT is just as easy :)
thats all good in theory til you are in a super late rush and the last thing you're thinking about is driving easy :)
Turbo timer = easy, lazy and you can just forget all about it
and that is the exact reason I haven't sold mine, and still want to get it fitted ;)
Won't use it half the time, like this wanker at the petrol station today, but its good to have when running late, when you're most likely on boost until you park it :)
The dude at the servo today cruised into the servo just before me (so I know for a fact he was taking it easy), and stood at the pump waiting for about 60 seconds while the turbo timer ran. I had almost filled up and paid before he started ;)
Oh and Kel, if you know how to install a TT into an alarm with a TT interface, then do mine for me please ;)
The dude at the servo today cruised into the servo just before me (so I know for a fact he was taking it easy), and stood at the pump waiting for about 60 seconds while the turbo timer ran. I had almost filled up and paid before he started :)
are you sure you aren't mistaking me for a man caus I did the same thing today hehe :)
do you drive a green s14? :)
I thought it was funny...I'm not one to turn off my car straight away....but when i've cruised off boost entirely, and pull in to fill up, I dont sit there and wait...was funnier because he was out of the car standing there with the fuel door open waiting :)
I'm with Roy on this one. But you can keep the Carlton, so you'll be even further ahead.
Then you need too plan better. And whatever you are heading for will still be there in the 30 seconds you lose by driving sensibly.
Turbo timer = ... lazy...
Exactly!
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
