A few people have shown an interest in my new little toy - the Orange TPMS (Tyre Pressure Monitoring System) and wanted to know more about it. I must admit I first heard about it fro Jeff Beable who runs one in his Targa car - but then also was shown 1st hand the effectiveness of them on the Maserati Quattroporte James and I drove which told me about the flat tyre before I realised.
I'll have it on the car this weekend at DECA to get a real feel for how good it is but basically it's a little gadget which has sensors fitted inside all 4 tyres which then provide information on both tyre pressure and tyre temperature to you live in your car. You can also set "alarm" points for low tyre pressure and high temperatures.
I got mine from Bit Distribution in Bayswater for $315 - Bit Distribution
In the last 12 months or so I've managed to delaminate a number of semi-comps on the skidpan basically from over heating - so I'm hoping this will help stop me from doing that. Also - earlier in the year I destroyed a tyre from driving on it flat (sidewalls were so hard I didn't realise it was flat until it was too late).
So pretty much if this thing can save me 1 tyre it will pay for itself. Also it means I don't have to get out and check each tyre regaularly on the track and can also get a better understanding of how quickly tyre temps come up and go down on the track because I can see all the data live. It will also show me if my tyres are overheating due to excess wheel spins on the skidpan.
More information on the unit is available from thr Orange Website here - Orange TPMS
https://www.sau.com.au/forums/topic/143398-tpms/
Hey Snowy
Ive had TPMS on my 34 for the past 12 months, its a very handy gadget :P
Mine is a little bit different as it displays all tyres at the same time, its seems the one you have displays one at a time
Ive attached a pic of the display, note pic shows tyre pressure in bar but is selectable to psi
Cheers
https://www.sau.com.au/forums/topic/143398-tpms/#findComment-2679286
how much 4 ur one CNBLOW...not that I need it, but I like buying stuff.
actually as Snowy said, I had the issue of driving on some low profiles and it was flat and I didn't know....wellldidn't know until I went around a corner and the tyre came off and I just missed an oncomming truck as I span out...not cool.
https://www.sau.com.au/forums/topic/143398-tpms/#findComment-2679581
Details would be great,
One of these would have been handy when my tyre went down through the flip flop at calder!
https://www.sau.com.au/forums/topic/143398-tpms/#findComment-2679620
hey guys
The TPMS i have is direct from the manufacture, i did extensive R & D for more than 6 months on this product alone working in conjuction with the manufacture to get his product 100% (ie software bugs)
If people are intrested in the product, i can try and find out some prices if needed
In the 12 months i have been using it, its never failed once
https://www.sau.com.au/forums/topic/143398-tpms/#findComment-2681898
hey guys
hey mate
details...who makes them and roughly how much. where are they located?
the other one Snowman posted is pretty wicked though. Reading through the install manual it looks pretty easy.
Hey Snowy...does the trasmitter sit around the existing tire valve..i.e. the valve stick through...I couldn't work that out. I saw they installed it from inside...not sure how its gonna look I wouldn't mind I pic. The dispay unit looks tops though.
KJ
https://www.sau.com.au/forums/topic/143398-tpms/#findComment-2682911
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
    • That's some really horrible design with the way it's cut/shaped! Is there much damage to the box that failed in? IE, new fork and you can go again, or is it a total rebuild again? Id be trying to build that piece from scratch, and getting some reliefs added in the corner to hopefully stop breakage, and then swapping boxes ASAP, and then doing the same to the currently good working box. I'm assuming hard shifts have not been friendly to it!
