im after 1 as well... Nismo with white face is sexy (Nengun has it for around $600)
apparently the led light background is red or orange?
Andz JapanDyno has them all the time you might pick up a bargain
http://cgi.ebay.com.au/JDM-NISMO-SKYLINE-R...5QQcmdZViewItem
if link doesnt work ill fix when i get home
Yeah Steve, I actually saw this one. Thought $600 is a bit too dear for a newie so this one is possibly a bit too expensive for a second handy with 24K on it already and who knows if all the gauges and LED's are working......I noticed in the pic that the fuel needle is stuck at almost full while the other 4 needles are back to zero......it may no be an issue but for the extra few bucks I'd go for a newie I think, unless the second handy was an absolute steal. Thanks for the link though.
man never buy from ebay friend bought gtr dash for hes car and it didnt even work wen he got it so much hassle tryna get money back n shit u just end up losing money...sometimes its alrite but u dont know what ur really gona get
Items:
Aftermarket Rear Bumper for S1 r33 Skyline
Rb25DET full engine and gearbox package!!! wanting everything needed 2 do the conversion!!! converting my GTS-4 s1 r33
Extra Info:
MUST be in good condition,any colour, some1 ran into the back of me and need 2 replace it!!!
Low Km's no shaft play on the turbo, good condition not tired
Contact Details:
PM me or msg me on 0423866853
Price and price conditions:
Cheap!!!
send ya offas and ill get back 2 you with the engine and gearbox!!! hoping to do the conversion just after christmas 4 me bday!!!
Edited by blacky_r33_SA1
i'm after a set of 4 wheels 16x8's or wider (5x114.3)
Tires either need to be pretty good or not have tires at all.
Price is dependant on whats on offer, not looking to spend much though as they're only going to be track wheels so condition doesn't really matter either as long as they're still round and true!
Cheers!
Items:
Aftermarket dump + front pipe suitable for my s2 R33
Extra Info:
good condition, Mild or stainless steel
Contact Details:
PM me or msg me on 0430 588 797
between 100-180
:domokun:
WTB: oil cooler kit to suit RB20DET
Preferably complete kit (filter relocation bracket, braided lines, sandwich plate that the lines plug into, oil cooler) or willing to negotiate if bits are missing
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
