Currently chasing a few things.
- R33 stock springs either coupe or 4dr as long as stock
- R33 glovebox
- R33 Steering wheel (must be near mint no rips or sun damage etc) and must be non- airbag s/wheel
- R33 4dr driver's door power window amplifier (R32 4dr may be same)
PM me if you have any. Cheers.
Have a set of 4 standard springs from my R33 2 door, nothing wrong with them, just no longer needed
Here is a link to them http://cgi.ebay.com....=STRK:MESELX:IT
Can contact me on 0433349400 for more info
Chasing a cheap front seat. Out of anything really as if for a track car. So R32, 33, etc whatever is cheap. PM me if you have something. Cheers
Hey mate, I have an S14 drivers seat with rail if you are keen?
WTB : Stock 1998 series 3 R33 GTR stuff.
R33 GTR standard ECU.
Front bar (preferably black).
Rear parcel shelf.
Rear driver's side inner trim.
Stock turbos (can be from a R34 GTR). Must be in working order and good condition!
Stock injectors.
Stock AFMs.
Also need coilovers for the 1998 R33 GTR. Must be in good condition and suitable for everyday driving on the street ie not too firm.
As well as an exhaust system including a cat that is not too loud and does not drone.
Looking to return a car back to stock so only really interested if I can get the lot. Don't want to end up with lots of parts that I then have to sell myself.
This will be coming out of my pocket for someone else's car! Which really f***s me off. Will need to swap over parts if you're able to help in that regard. Reacharounds for all.
Thanks guys.
r33 rb25det engine+loom and etc for det conversion.
need one as i am going to turbo my na r33 but my mate also wants to salvage parts off of it for his drift car.
pm me pricings and etc.
thanks guys :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
