WANTED in SOUTH AUSTRALIA;
WHITE R34 GT-T bonnet. I'm after a new one as mine has to many scratches and stone chips and at the moment im just looking for the best price for one (as i really don't need to change it as it's not causing any troubles, just thought if i could pick one up cheap, i might as well). So please PM if you have one, or know of one.
ALSO; are Carbon Fiber bonnets legal in South Australia?
Carbon Fibre bonnets are most deiniftely NOT legal in South Australia (nor the rest of Australia for that matter). They can not and have not passed ADR certification, as they are deemed to be a pedestrian risk as they tend to shatter when they hit someone, sending lethal shards of carbon fibre all over place.
But plenty of people run them anyhow :) At the end of the day in the police eyes all Skylines are illegal, fullstop.
WTB for R32 GTR:
Radiator Shroud without any snapped mount points
Hicas friendly Power Steering cap (with sensor + wire)
Right (Drivers side) Rear brake light bracket (plastic thing that globes clip into)
Genuine N1/Nismo sideskirt/pods
Stock GTR Underplastic diffuser + brake ducts
Front Castor rods
PM Me with details
-D
WTB these parts for a 1993 R32 gtst Type M
1: Clutch fan for rb20det
2: Fan Shroud
3: R32 Ash try and cig lighter
4: Trim that goes around climate control
5: Trim that goes around gear stick leather
6: Boot trim that goes on the back of the seat
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
