WANTED in SOUTH AUSTRALIA;
WHITE R34 GT-T bonnet. I'm after a new one as mine has to many scratches and stone chips and at the moment im just looking for the best price for one (as i really don't need to change it as it's not causing any troubles, just thought if i could pick one up cheap, i might as well). So please PM if you have one, or know of one.
ALSO; are Carbon Fiber bonnets legal in South Australia?
Carbon Fibre bonnets are most deiniftely NOT legal in South Australia (nor the rest of Australia for that matter). They can not and have not passed ADR certification, as they are deemed to be a pedestrian risk as they tend to shatter when they hit someone, sending lethal shards of carbon fibre all over place.
But plenty of people run them anyhow :) At the end of the day in the police eyes all Skylines are illegal, fullstop.
WTB for R32 GTR:
Radiator Shroud without any snapped mount points
Hicas friendly Power Steering cap (with sensor + wire)
Right (Drivers side) Rear brake light bracket (plastic thing that globes clip into)
Genuine N1/Nismo sideskirt/pods
Stock GTR Underplastic diffuser + brake ducts
Front Castor rods
PM Me with details
-D
WTB these parts for a 1993 R32 gtst Type M
1: Clutch fan for rb20det
2: Fan Shroud
3: R32 Ash try and cig lighter
4: Trim that goes around climate control
5: Trim that goes around gear stick leather
6: Boot trim that goes on the back of the seat
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
