Looking for r34 4 door driivers door glass, weathershield drivers side and ignition barrel and key.. Needed asap for a friend who had their car broken into and attempted theft..pm me if you have any of these. Thanks!
Wtb - drivers side r33 s1 power window regulator with motor. needs all rubbers and stuff in perfect working order as my window pops off the rails everytime it goes up because of a bad rubber. need it ASAP so please let me know if u got one
R32 Cat Back Exhaust. Obviously can be from a R32 GTR/GTST Coupe/GTS4/GTST 4dr
3-3.5" in size
Must have "middle muffler"
Would prefer NO CANNON at the section of the exhaust i.e. Twin 3" tips out of a muffler, single 3" tip etc. HOWEVER may be interested in one which has a "Cannon"
Must be close to legal dB reading i.e. 90dB (A) (I think the sound tests are done at A weighting levels???)
PM or contact me on 0401 317 009
require ASAP.
Cheers,
David
Edited by R32Abuser
