Urgent ...
Need that little hose behind the head/lower plenum, which connects from the lower intake plenum to the hard pipe which goes to the turbo around the back of the head. Its a little coolant elbow rubber hose.
Please PM me or call 0449 928 227 if you have one.
:thumbsup:
WTB - V35 18" wheels, premium spec, like these ones that someone had for sale on here a little while ago, i missed out.
http://www.skylinesa...ims-with-tyres/
If you have any that you'd like to part with, let me know via PM
Also chasing an RB25 clutch fan assembly including viscous centre.
Edited by Sorin-Andrei
WTB CAS Sensor R34 GTT. According to the web, its model 23731-5L30A which fits:
Nissan Skyline R33 GTS25 (RB25DE) / GTS25-t (RB25DET) / GTS-4 (RB25DE)
Nissan Skyline R34 GT (RB20DE Neo 6) / 25GT (RB25DE Neo 6) / 25GT-4 (RB25DE Neo 6) / 25GT-t (RB25DET Neo 6) / GTR (RB26DETT)
Tried to go down to JIS this afternoon, but despite their website saying closing time at 3pm, turned up a little after 2pm and closed up.
Hi guys, had some work done on car, looking to upgrade ECU from the stock rb25det one, mine is an Auto Coupe'! been looking seriously at getting NISTUNE :D does anyone have a nistune board to suit even if its in the Z/R32 ecu as long as its all prepped for auto R33 :-)
definitely the next addition to my car I believe to make a difference in the overall drivability/power/acceleration etc of the car to get this nistune and get a proper tune done :)
thanks guys if any1 has one to sell or can suggest a good place to get one?
CHEERS
MIKE
CHEERS
MIKE
Best bet is to find the best ecu for the application in the second hand parts thread (I see them all the time) and then see Pete from PLMS for a cable,nistune board + installation - he'll take care of you
Got mine around 2 years ago, was a great investment
-D
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
