Can anyone tell me if this cam CAS drive can be changed or is it fitted for life ?
Also those late/last 97 R33GTST's , did anything electrically change with the ECU and CAS itself ? Does the on R33 GTS25T PFC work with them as well or model specific change/mod ?
Cheers A .
https://www.sau.com.au/forums/topic/144071-late-r33-gts25t-ecucas-qs/
What I want to know is can the "peg" or drive in the camshaft itself be changed from late 97 R33 RB25DET type (same as r34 ?) to the earlier type half moon/spline arrangement . I guess if the answer is no then does the late R33 GTS25T CAS (black plastic dome type) plug into and work with say the 96 models loom/ecu er PFC .
LOL cheers A .
This is an interesting question, hence why it is being asked.
There appears to be 4 types of CAS used on R32/33/34’s.
1. All R32 and R33 S1 (half moon drive)
2. R33 S1.5 (half moon drive)
3. R33 S2 (star drive)
4. R34 (star drive)
But don’t R33’s in S1, S1.5 and S2 all use the same Power FC? So the internals of the CAS should be the same. If so, why did Nissan change the CAS from half moon to star drive? Unless the internals of the CAS are different, but the Power FC doesn’t care. Either it just ignores the differences or it compensates for them.
As I said, an interesting question.
:D cheers :)
:D cheers :P
I have seen the half moon snapped off.
Maybe it was a simple design change to prevent this?
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
