Why is Victoria also the state with the most local/militant unions as well?
Just out of curiousity, who do you think are the militant unions? There probably are some, but doesn't mean they all have to be laballed as the same.
I'm a unionist (I'm an electrician, so a member of the Electrical Trades Union), and they make sure they do everything by the book. Unionism had a bad light a few decades back, but now they are a very proffesional run organisation, who also look after each and every member.
  • Replies 43
I did a significant amount of work on the the eastern water recycling proposal and I know a lot of people in the power industry and various water authorities and I can say without a doubt that its the biggest load of crap! To say nothing of the cost issues when it comes down to it the water saved will be sent to industry, a small amount to Geelong and pretty much all of the rest will sent down the rivers to boost flow. How will that help us? What do we get for the billions of dollars and in increased cost of electricity? Nothing!
The tool has also promised to spend 3 billion dollars in the next 5 years upgrading the easter treatment plant. 99% of the people in the water and power industries know his promises on these issues are a total load of crap.
On the other hand Ted is a multi millionaire isent he with investments in so many companies? I can see his decisions if he wins just done to help line his posckets more.
I belong to the working class, i used to vote for labour but now i dont' believe in any of them at all so i VOTED for the GREEN.
I voted for the GREEN now i thought about it i'm like F**K me, what if they want FOUR CATs in every cars to keep the GREEN GREENER!
Oh well, too late :rofl:.
Dont' forget to pick up today Herald sun, free DVD copy of Making Poverty History concert.
You guys only have to vote for politicians every now and then. I have to live with one :rofl: And after seeing all the rubbish first hand, I simply never enrolled and dont plan to vote. Its a dirty scummy game to be in IMO.
Martin Kingham's mob is pretty bad, not as bad as the BLF where though (I had a number of run in's with them.) I have no issues with the principle behind union's, it's some of the policies that they have that I have problems with.
vote labour!!
liberal wants more cops on the roads!
True, they want a more visible police presence, not hiding in unmarked cars and behind speed camera's. They are also going to introduce a more realistic tolerance to speeding, and give cops more discretion when it comes to either warning or fining drivers.
and when you get your defect you'll know who to thank ;)
Yep, myself for driving a vehicle with defective items, common sense suggests that.
Although there may be others who believe the Police or the government are to blame for them breaking the law, I say good for them! ;)
Edited by ToF
if your sense thinks that having an exhaust/bov etc qualifies as a offence that justifies a $$$ penalty, then you obviously think that these modifictions seriously warrant a car unsafe or "defective" so as to endanger your well being.....and so therefore you must be grateful that bracks and his new laws step in to protect you from harm...... ;)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
