  • Replies 612
Not ready to make nice - Chicks with Dix.........errr, i mean...Dixie Chicks.
I'm not listening to it by choice they play it on the radio 10 f**king times a day. And I can't change the radio station at my work.
If I hear the song one more time I think I will kill someone.
listening to a dvd that godthrilla sent me. f**kin cool man
underworld ftw!
watching or listening
cause there is a kick ass movie with kate beckinsale (she of great tits) called underworld
then the follow up called underworld:evolution
Underworld - Born Slippy
Drive boy dog boy dirty numb angel boy
In the doorway boy she was a lipstick boy
She was a beautiful boy and tears boy
And all in your innerspace boy you had
Hands girl boy and steel boy you had
Chemicals boy Ive grown so close to you
Boy and you just groan boy she said
Comeover comeover she smiled at you boy.
Let your feelings slip boy but never your mask boy
Random blonde bio high density rhythm blonde boy
Blonde country blonde high density
You are my drug boy youre real boy speak to me
And boy dog dirty numb cracking boy
You get wet boy big big time boy
Acid bear boy babes and babes and babes and
Babes and babes and remembering nothing boy.
You like my tin horn boy and get wet like an angel.
Derail.
You got a velvet mouth youre so succulent and beautiful
Shimmering and dirty wonderful and hot times
On your telephone line and God and everything
On your telephone and in walk an angel.
And look at me your mom squatting pissed in
A tube hole at tottenham court
Road I just come out of the ship
Talking to the most blonde I ever met.
Shouting
Lager lager lager lager shouting
Lager lager lager shouting
Mega mega white thing mega mega white thing
Mega mega white thing mega mega shouting
Lager lager lager lager mega mega white thing
So many things to see and do in the tube hole
True blonde going back to romford
Mega mega mega going back to romford
Hi mom are you having fun and now are you on
Your way to a new tension headache
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
