you'd be best off doing the dump/front pipe as well. then you would have to run it at stock boost as it would flow more air than the stock one, so if you went higher you may hit rich and retard. other than that it would be fine.
as he sed, finish ur exhaust, buy a boost controller and an ecu and tune it. i wudnt run it for too long or give it too hard until uve tuned it, just to be on the safe side.
Edited by moonus
im running slide hiflow,full 3" exhaust n dump, cooler,walbro pump and about 14psi...it feels good but the stock ecu holds the hiflow back something bad..i mean i can barely pull away from stock 33's that are running cooler/exhaust and 14psi :laugh:
Edited by l0WRB
Ive got a highflow, sitting there waiting to go on (found a R34 gcg highflow at a price i couldnt pass up).
batmbl split dump and highflow cat
catback 3in
Turbosmart eboost 2
I ran my standard turbo at 10psi for only short periods. Would the highflow move more air at stock boost than the standard at 10psi?
Im thinking if i run it at standard boost, and set the wastgate pressure to open up at low boost (eboost 2 gate pressure function), will this be ok to cruise around with for a while. Then i can sell my stocko turbo and get FMIC or more likely a PFC while they are still around. Also on the cards is fuel pump and injectors when the $$$s allow.
cheers
Evil
Edited by EvilINGT
I realise that boost is only relative to each specific turbo. Which is why i ask if a gcg highflow moves more air at stock wastegate pressure than the standard turbo at 10psi.
Which also leads to the question, what boost is the wastegate spring set to on A- a r34 turbo, and B- a r34 gcg highflow turbo (sydneykid some help maybe :D )
cheers
Evil
  • 5 weeks later...
ok.. if i have roughly $500 to spend on after turbo upgrade.. what will be the best thing to spend it on? keep in mind.. i only have catback and fmic. cause it doens't look like i'll be able to afford a new ecu for awhile.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
