:laugh:
sorry i couldn't resist...not many Kyles around :)
P.S. I could actually do this if you were in melbourne :)
lol im not in melbourne ahah i need somebody that actually knows what their doing without going ohh yeah cost ya 300 hundered den end up paying bloody 400 more ..
contacted fats for kyles number hope he comes through
not many sydney sau members are skillful in these departments???
Plenty of people can do it but it's all a matter of time.
lol yeah plenty of people pay 600 bucks for one time added altogether and then they screw it and then get other people to do it n charge you more to undo other mechanics mistakes and make their own adding more costs..
all i needed was any guys to go aye yeah we'll do it properly.... so dody performance shops serious i'd attemt it myself if i knew how
im in syd, qualified mechanic own a skyline(i think this is an advantage) ive also installed manifolds of this kind before, just a lil hint, get hold of all new head studs for the manifold + all new gaskets. also potentialy get some new braided hoses, depending on the manifold, studs+ gaskets are a must for good practice :D
it's pretty piss easy mate, just take your time and remember that lube is your friend (when isn't it?).. make sure you've access to new gaskets though
If you think about it, any car work is piss easy in theory. E.g. undo the bolts, take the old one off, put the new one on.
But in practice, that is never the case.
e.g. recently, I installed a dump/front pipe which I bought off someone recommended. It didn't fit straight on. Other things needed mods, the pipe needed to be modded a bit with an oxy torch, and a grinder etc.
There's a good chance that you'll break studs. The new manifold might move the position of the turbo ever so slightly (that's what happened with my dump/front pipe. It looked good, but being in a different position meant it wouldnk't bolt on) you'll have to redo the exhaust and top side piping etc.
So, nothing ever goes as planned, and nothing is really ever easy
here is a good guide for installing the manifold which i followed the other week and i also installed a q45 throttle body as well, it was a shame that i found this guide after i broke a stud.
http://www.livesockets.com/quoc/rb/6_intak...ifold/index.htm
also there is lots more discussions and information about these manifolds at
http://forums.racebread.com/index.php?board=47.0
hope this helps
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
