Well with the wii you have two options
composite - blurry
component - jaggy
Wii isn't capable of graphics like that seen on ps3 or 360. Please note that i am not saying the games are crap but that the graphics aren't that flashy, i know it's all about the gameplay.
  • Replies 99
Bought Tiger Woods 2007 yesterday. Great fun and more than enough modes to keep you busy for hours. Getting the hang of the Wii remote as the interface for this one is hard though. Could be just too much time spent playing Wii Sport Golf.
godfather: blackhand edition came out yesterday... looks pretty good... does anyone know if excitetruck is any good? whats the control scheme like?
Excite Truck is awesome, it's very over the top. Insane jumps and great sense of speed leave you feeling like you are just on the verge of losing control. It looks pretty good too (for a Wii game). I had lots of fun with that game and there's a fair bit of stuff to unlock. Multiplayer is a bit of a let down but, no online and only 2 player split screen (no other cars). I would recommend this game is at least worth a hire if you are unsure. Also if you don't like the widdly widdly cock rock sound track you can put your own songs in if you have an SD card too (but the widdly makes the game IMO!).
I've heard good things about Godfather:Blackhand Edition on the Wii as well, I'll give it a hire.
I liked GT Pro as well, thought the controls were good and didn't have any problems after you get used to it. I wasn't able to try it out with the wheel attachment but.
EXCITE TRUCK IS AWESOME!!!
What he just said x2!!!
If you have a wii you need to get excite truck!!!! I'm looking at getting godfather this week coming, I've heard its good! I'm still not finisheed zelda yet, I'm so lazy :happy:
Wii is good ! :)
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
