seemed like it cause it wasnt a full on dyno run, virtual 1/4 mile i reckon
still fcuken awesome
about a 12.5 -13 sec pass by the sounds of it
Edited by usherly
LOL how the hell do you come up with a figure like that by listening to it... 13 seconds is stock times and that is deffinately not a stock GTR ....
if you watch carefully it is accelerating for about 12-13 seconds... It could have been faster i guess.
I doubt however that even if they are doing a simulated quater mile run that they have hit the brakes once they had gone the equivelent of a 400m distance.
look thats what i got from looking at the times
i dont doubt it could be a quicker car, im saying that, if it was a virtual 1/4mile, that pass was about 12.5 to 13 sec
ahwell ... all we can say is that it ran on the dyno for that long its impossible to know exactly what they were doing..
Edited by fEkuaR
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
