Guys, as titled, I need some assistance with a Grex oil cooler. The model I ordered should fit into the right inner fender. I guess that means the drivers side right? But all the pictures in the japanese instruction book refer to the passenger side? WTF is going on?? I am trying to fit the cooler in front of the factory BOV but I have never seen a cooler mounted there with the BOV's still installed. I wish I could read japanese. Can anyone shed some light?
Thanks for that. Grex make a number of different kits. They all have various length hoses depending on the coolers location. Has anyone fitted the grex cooler infront of the factory BOV's?
I'm not sure if its going to fit and my instructions are for the wrong location :happy:
I got a HKS oil cooler it goes on the passenger side , the lines run under the motor
I highly doubt you can fit it (any cooler) in front of the BOVs. mine is in the passenger side duct. mine is a grex kit also. the big one. and it just barely fits in the passenger side duct.
ive spoken with the guys at meridian motorsport about an oil cooler for my gtr and they say they have never fitted a cooler to the drivers side. they have always put them on the passenger side
i have a large one.
mines mounted horizontal (laid flat) here....
shot is from under. and its more over to the passenger side. left part is front lip
max temp today was 85c which was driving for a long time with a fair bit of hard driving (i went bush)
Edited by Angus Smart
I hav a grex cooler kit mounted in front of the blow valve on my 33gtr... i had to convert to greedy type r as the standard bov's would hav needed to be modified (re bracketed and chopped) to fit the cooler in place....
you know the inner fender probably refers to the area right in front of where the RHS front wheel arch is...
i.e the position where the GTSt ventilation slats for the SMIC are cut into the inner plastic guard on the passenger side, but on the driver's side...
so the cooler sits not against the front bar, but behind the BOVs nearer to the wheel well?
does that make sense??
What size cooler and was it a Trust / grex one? Do you have pics? The instuctions I got with the cooler shows installing it in left inner fender. USELESS!
I must be the only one with a 32 GTR who installed my oil cooler in front of BOVS....special. It can be done.
19 row oil cooler kit from UAS, earls fittings etc. Tight fit near one of the BOVS but the reason mine fitted was that I had previously removed the BOV piping. Also made brackets from aluminum to mount cooler.
That's great. Thanks for the pictures.
I purchased the Trust / Grex unit because it's of high quality and I prefered a vehicle specific kit rather than making brackets and having hoses made up for a universal kit. That's why I paid the extra money for it. But it seems unlikely this kit can fit in the intended location without changing BOV's or stuffing around. Not happy. I was assured this unit will fit without any modifications from the supplier, whitch I have in writing.
Some pics of my setup:
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
