^^^ Perfect, so you got rid of the CF bonnett?? Did you have cop dramas with it on or you just preferred the look of the stock bonnett?
Thanks man. I had 1 cop tried to defect me for it and i told him its a V-spec 2 and comes with a carbon bonnet. He looked at me like a was an idiot. I told him go look it up, u have the chose to keep it black or paint it the same colour as the car!!
But i preferred the look of the standard bonnet! Looks better.
yeah cool, I like the cf bonnet especially on a black car like mine but dont need any more things making it more of a cop magnet. If they see the bonnet and pull me over Ill then get done for the pod filters also.
Had some shots after cleaning the car last friday evening...and before killing the headgasket on the Autobahn doing some 200km/h runs...now engine won´t rev any more, filled cylinders with coolant...
Hey all R34 owners out there... if you have xenons or even standard headlights and have noticed some discharge build up on either the inside or outside of the headlights and can't remove it with plastix or similar product check out this GB:
http://www.skylinesaustralia.com/forums/-t248378.html
GB is useless, you just need to machine polish the outside with paint polish. You just need an aggressive pad and polish combo
Well that could be correct for some owners but mine actually have discharge on the inside. Thought i'd post it up here as some people might be interested.
correct, im going to try the buffer pad on the outside but im pretty sure its all in the inside now as ive used plastix and it got rid of most of the outside crap. but hey, ull never know until you try it,
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
