dori thats f**king crazy man. does it scrup at all in the rear???
the 350Z wheels are temp wheels. got them at a great price. couldnt say no. wont be painting them black. had black wheels before and ye it wasnt my cup of tea.
as for fitting no spacers needed BUT if your plannin on lowerin your car the front guards will need to be rolled. my car is actually fairly low (driveway is in an angle so makes the car look high) and my front wheels scrub on full lock while entering driveways or if the car bounces on the road too much. but other then that no major issues at all.
thanks for the comments.
18inch?? What would they set u back if u dont mind me asking?? Direct fit?? or need spacers??
yes 18s. its 18X8 +30offset. bought rims only for $200. tyres i got a good deal on a set of dunlops whci i can always get put on other 18's.
Some night shots for me last night (shortly before getting defected whilst driving around looking for more good photo locations .. *sigh*) ..
You should be able to click on those for a larger image too.
Overall, I'm pretty pleased with the results.
Certainly not bad for a cheapy camera - just wished it had raw capability so I could have done more with them post-processing...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
