damn that's nice, haven't seen it around canberra though.
Yeah - I need to get out more :rolleyes:
Hey Marko, Yes I am good at it. I did a good job of preserving one of australia's best aust delivered R32's for a number of years! (miss that car)
The wheels are a limited edition enkei RPF1-RC. Made for the R34 gtr supposedly?
This pic has been taken by Dean Summers from Just engine management.
1st time ive seen this pic & must say it reminds me of that yellow phase 3 ford falcon gt pic that was taken @ for muscle parts back in the 80's...the point i am making, this pic has the appeal to be a classic & i could see this on many bedroom walls!
lol definitely not z-tune skirts mate, i wish! see that bit of black rubber on the front bar of the car?
its the same as that, just all the way around the side skirts and rear bar. bought the stuff from Charles89 (vic member) in a group buy like 2 months ago.
looks ok for $40
i've never seen a GTT with z-tune side skirts, only GTR's...i imagine it would look phat as tho!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
