East Bear make a "GTS-R" badge.
But in a shape of the GTR badge.
haha yea i know, simply saying i dont like them, ie if i ever did the conversion i wouldnt put badges on it.
avoiee is that a genuine front bar or a fibreglass one made to fit the gtt?
Front bar (i call it bumper cover) , lip , diffuser and bonnet all are genuine parts from BNR34, front bar took quit a modification to fit nice on GTT fenders
red one - 1993 r33, was modified with engine swap for rb25det, all body had modified - gtr33 : rear fenders, sideskirts (metal ones), and gtr34 - front bar with hood. the front fenders 334 are custom made. paint - House of Color Apple Red Candy
you can check the project with some pics here, although it's in russian...
http://www.nismo-clu...showtopic=38796
blue one er34 GTT MT, body - all round gtr 34 (including original rear fenders, all front with Z Tune bumper). paint House of Kolor Cobalt Blue Candy
will update with more pics soon..
the blue r34 gtt had me fooled looking at the photos, would of swore genuine gtr, very impressive work and the candy apply red color looks nice too.
LOL!
I just re-read your post I quoted.
I see what you mean now :)
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
