I love these one's as they remind me of mine :D These pics have been used and abused a lot....
This one is from a cruise down to some Dam south of Sydney, off the Hume Hwy about 3-4 years ago.
I took a couple of shots, I'm sure this is one of them...dam nice car!
I love these one's as they remind me of mine :D They have been used and abused a lot.... post-12712-0-97772500-1348142930_thumb.jpgpost-12712-0-62247500-1348142953_thumb.jpg This one is from a cruise down to some Dam south of Sydney, off the Hume Hwy about 3-4 years ago. I took a couple of shots, I'm sure this is one of them...dam nice car! post-12712-0-82833100-1348142954_thumb.jpg
Isn't the first pic of that white GTR one of 3 Kaizo kit cars assembled in the US?
haha yeah GTSR badge chosen because GTR badge is rice to put in GTT. but other way - i love the GTR badge look so choice was GTSR one.
@blah_blah yep this is GTT with all GTR bodykit with original GTR front and rear guards and nismo carbon bonnet
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
